Shed Floor - Options To Make More Rigid? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-09-2016, 08:39 PM   #1
Rewards Points: 26
Shed Floor - Options to make more rigid?
I am assembling a 12'x8' shed kit. The floor is made up of 2x4s, spaced 24". This will sit on two 4x4" skids that are on levelled concrete blocks. I am putting 3/4" PT plywood sheathing. The shed will hold garden tools, bikes, winter tires, nothing crazy.
Right now the skids are 6' apart, which means the shed floor extends 1' past the skid. Too late to upgrade to a 2x6 floor, I am considering one of the following to firm things up.
1) adding a 3rd 4x4 to cut the 6' span to 3'
2) Adding more 2x4 joists to make the floor joists 12"OC
Any thoughts on what would give me better support? #2 would probably take 20 minutes and cost me only $15 in material, while #1 would be $30 in material: blocks, bags of gravel for base prep plus the 4x4 and probably take me more than an hour, to dig, prep and level.
kal72 is offline   Reply With Quote
Old 07-09-2016, 09:13 PM   #2
Rewards Points: 14,026
Re: Shed Floor - Options to make more rigid?
It's needs that third 4 X 4 or it's going to sag and the door will stay out of wack.
A 2 X 4 joist at 24 O/C would be a disaster, add those extra joist, with the joist that close to grade I would be using PT.
If that shed's walls are not at least 6" above grade there's going to rotting issues.
What do you mean by 3/4 PT for sheathing? Do you really mean for the sub floor?
I would not use that for a sub floor or for sheathing, it's going to be soaking wet, full of voids and loves to delaminate, no T X G.
Use Advantech instead.
Old 07-09-2016, 09:29 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 1,998
I agree that door #2 is the best way to go. At 6' your are right at the span limit for a 2x4 no matter how many your have.
If it's not too late you might see if you can find deck blocks that are grooved for 4x lumber. Regardless, your blocking should be set on pads of several inches of limestone screenings or something similar for drainage. If you are in an area subject to freeze-thaw try to avoid using hollow concrete blocks.
I agree that a plywood floor is perhaps not ideal but I did the same several years ago in a house we used to own and it is still fine. Unless you use it in such a way that brings in a lot of moisture (like a snowblower), a shed floor stays fairly dry. It is, after all, a shed.
lenaitch is offline   Reply With Quote
Old 07-10-2016, 06:40 AM   #4
Rewards Points: 26
Thanks for the replies. So I will get a third 4x4... Sounds like adding the extra joists at 12" oc might not be a bad idea either or wouldnt be needed with the third 4x4 beam? After reading Joes reply, I just read about the advancetech flooring - never heard of it until now but a little too late. I thought I as doing well by listening to the Lowes guys and spending 3 times the price on PT vs OSB.
All my floor assembly is pressure treated including plywood floor -the plywood will be 6" above grade. I have the 3/4" crushed and screening under my block, but I did use cinder blocks with holes and I am in Ontario...hadn't heard how they work or not in freeze thaw.
Old 07-10-2016, 08:15 AM   #5
Rewards Points: 236
3 4x4 skids. 1 in the middle, the others all the way out under the wall = NO overhang .
2x4 16o/c would be ok for what you are doing. 12" o/c would be better = in case you get a tractor or motorcycle or whatever.
your plywood is fine. just glue the gaps when the shed is done.
and don't let the plywood get wet, cover it if its going to rain.
Fix'n it is offline   Reply With Quote
Old 07-10-2016, 08:16 AM   #6
Rewards Points: 236
oh. i am building a 10x12 right now.
Old 07-10-2016, 09:19 AM   #7
Rewards Points: 26
Thanks Fix!
What do you mean by "Glue the gaps"?
I already have it framed at 24" OC, so easier now to just add joists to make it 12" (16 is no longer an option unless I re-do).
No overhang makes sense now that I am going to 3 skids, but too much rework at this point to do that. Best I can do is to probably have 8" of overhang at the door, and 12" at back of the shed.
Old 07-10-2016, 05:22 PM   #8
Usually Confused
lenaitch's Avatar
If you can still get at them, consider filling the block holes with screenings.
Old 07-10-2016, 08:25 PM   #9
Rewards Points: 236
you probably will not have open gaps where the ply meets up (mine does, so i am going to close them with construction adhesive.
yeah, go 12" o/c.
lets see a pic of what you have.
Old 07-11-2016, 08:08 AM   #10
Rewards Points: 26
I guess the undersized shed kit floors are a common theme. The 2x4 joists didn't surprise me, but the 24" centers did.
I have added the third 4x4 beam in the middle and gone to 12" centers.
I will load the hollows of the cinder blocks with my leftover screenings.
The only recommendation I didn't do was to have the outside 4x4s line up underneath the rim joists at the front and back. I have a 12" overhang front and back.
The instructions say to toe-screw each joists to the 4x4 beam. Wondering if I should also PL Premium the joists to the concrete block?
Finally, should I be gluing the floor to the joists or just nail.
I have a feeling i will have more questions as I start to build vertically!
Thanks all!
Shed Floor - Options to make more rigid?-shed2.jpg   Shed Floor - Options to make more rigid?-shed22.jpg
diycoder's shed project diycoder Project Showcase 52 Yesterday 11:00 AM
Options for moving shed handeman General DIY Discussions 3 05-31-2016 07:16 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Conduit questions in shed wiring TheCowGod Electrical 28 03-18-2012 01:42 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
