Shed - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-19-2013, 07:16 PM   #1
Rewards Points: 81
Shed
Not sure if this is in the correct thread or not.
I received an old shed that I am converting to a chicken coop. It's an 8' x 8' x 7.5' gambrel roof style shed. I am not installing the floor since I want it to be a deep litter dirt floor.
I am laying pressure treated 4x4's on the ground, then attaching the bottom plate (also pressure treated) to that. Basically, I will end up with a shell (walls and roof) with a dirt floor. The area I plan on putting it is level. No grading required. My question is ---- Can I lay the 4x4's directly on the ground (no gravel, slab, etc)? Or should I dig out a small footer or....other suggestions?
cougar01 is offline   Reply With Quote
Old 06-19-2013, 07:24 PM   #2
Rewards Points: 14,026
If you want it to last longer lay own some #57 stone first for drainage under the 4 X 4's.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Zoning issue with planned shed Ler0y Jenkins General DIY Discussions 15 02-01-2012 12:41 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
