Settled Sidewalk - Help - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 09:02 PM   #1
settled sidewalk - help
Hi, my sidewalk is not broken, but settled on one side only (the side near the lawn is fine, but the side near the road is settled by 4 inches). Apart from the settling, its not broken. The settling is pretty much even along the perephery (along the road side).
How do I fix this? Do I have to break/remove the entire sidewalk and then pour the new concrete mix? or can I use the same settled sidewalk as the base and pour concrete (quikrete) over it? What will the problem be, if I do it the this way?
Please give me a solution... thank you all
saturn78 is offline   Reply With Quote
Old 09-09-2009, 08:56 AM   #2
TooledUp
Check with some of your local concrete companies. Some of them have a process where they drill holes and then pump concrete under the existing concrete to lift if back up.
TooledUp is offline   Reply With Quote
Old 09-09-2009, 09:15 AM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I had this problem at a house I used to own. There was a chance we were going to be moving in the near future, so I wanted to keep costs low. what I ended up doing was digging down along the sloped side, i then used a 6' slate bar, and a log as a fulcrum and lifted the sagging edge high enough to toss in a couple shovel fulls of sand and gravel. Then i simply repeated the process a few times, until i was able to get the sidewalk up to a respectable level.
It took a while, but wasn't hard work, and literally cost me nothing ( but i did bend my slate bar).
I did this about 6 months before we ended up putting the house on the market and it held up great as of the day we moved out. no idea if it has sagged again since.
Mr Chips is offline   Reply With Quote
Old 09-09-2009, 09:32 AM   #4
Thanks for the response Chips. Not many people will like to hear this, but I'm willing to repeat what you did every 6 months, if it doesn't cost me anything
Unfortunately, in my case, the sagged side of the sidewalk abuts the road and the kerb on the edge hasn't settled. I'll have to look for innovative ways to deal with this as money is hard to come now a days.
Pavers over a concrete sidewalk Beckerad Flooring 3 07-20-2010 08:59 PM
Advice needed for draintile under sidewalk dgbehrends Landscaping & Lawn Care 5 11-17-2009 12:03 AM
How to rough up concrete sidewalk maryj Landscaping & Lawn Care 5 09-09-2009 08:41 AM
Sidewalk drainage issue! Bcoleman6 Building & Construction 1 07-07-2008 02:17 PM
Sidewalk Meets Concrete Truck Question craigNeasttx Building & Construction 5 03-24-2005 11:40 PM
