Septic Drain Field - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-27-2010, 09:34 PM   #16
Civil Engineer
Rewards Points: 4,526
The best way to determine if a tank needs to be pumped is to open the cover, and measure the depth of solids using a wooden probe that you plan to throw away. If the solids are less than 15 percent of the depth of liquid in the tank, no need to pump. If more than 15 percent, time to pump. By the way, there is good evidence that a properly managed system can go upwards of 20 years with no need to pump. Specifically, no garbage grinder, don't toss bulky vegetables down the drain (compost them), use limited amounts of laundry detergent, you may never develop large amounts of solids.
Daniel Holzman is online now   Reply With Quote
Old 04-27-2010, 10:59 PM   #17
Military Mom of 4
Snav's Avatar
You should routinely pump, though, so the tank, baffles and inlet can be checked for fractures and other issues. A system can be relatively low on sludge but still have other issues that need to be addressed.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Problem with septic drain field Patriot_RAM Plumbing 7 04-21-2009 03:55 PM
Septic Order coming from Shower Drain CherylB1216 Plumbing 1 03-15-2009 06:16 PM
Sink doesn't drain into Septic but somewhere else? 40s house? Where? twilightcall Plumbing 11 01-18-2008 09:36 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Severed septic drain field line tripower Plumbing 2 08-14-2007 02:05 PM
