Seed Grass In Fall Or Spring? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 11:16 AM   #1
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Seed grass in fall or spring?
I have 2 places in my yard, under the shade of catalpa trees, that I can't get grass to grow. The soil was tested at the University extension center and they said it's fine. We have seeded with dense shade seed in the spring and even tho we keep it watered it dies out in August. I till and rake it before I plant. It grows like crazy til the weather gets hot. Should I seed in the fall instead? Should I put straw on top to hold in the moisture? This is in southern Missouri.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-13-2010, 11:46 AM   #2
Handy Vinny's Avatar
Rewards Points: 150
I would seed in both Spring and Fall, covering the seed with peat moss instead of straw. Water daily and the peat moss will keep the area moist, as well as disguise the seed so birds will not eat them.
Straw does nothing for moisture retention; at best, it is semi-effective barrier against birds. Perpetually wet straw can also propagate mold, which can kill new grass crowns and exacerbate an already bad situation.
Good luck.
By the way, it sounds like you probably need a shade mix. I use a 4-fescue shade mix when I seed for clients. It has never failed me. Go to a nursery or garden and feed shop; they will be able to help you. I might add that growing and maintaining grass under trees--especially trees with high root systems, like maples--is an ongoing battle. That is, you will probably have to do it every spring and every fall.
Handy Vinny is offline   Reply With Quote
Old 09-13-2010, 12:22 PM   #3
Rewards Points: 1,010
I've heard fall seeding allows for better root density and depth the next year.
If not, I'd go with astro-turf. And a putting green.
spaceman spif is offline   Reply With Quote
Old 09-13-2010, 12:34 PM   #4
Rewards Points: 150
Fall seeding is really only effective with regard to root development if it is coupled with aeration. I have never heard anything that says fall seeding alone is sufficient to developing a lawn's root system. Then again, I can only speak for my geographic area, so you could be correct with respect to a different area of the country.
AstroLawn or something artificial like that would be extreme and very expensive. And unless I missed something, there is nothing in the OP's post about golf, so a green, as you say, might be superfluous.
Old 09-13-2010, 07:54 PM   #5
Don't know it all, yet!
Look at this:
http://extension.missouri.edu/public...b.aspx?P=G6700
Instead of me disagreeing with other posts on here, this is from the University of Missouri. It's the same thing I would do here in Atlanta, but here it is from your area.
Good luck.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 09-14-2010, 05:46 PM   #6
Rewards Points: 150
Originally Posted by downunder View Post
Look at this:
Good luck.
Sure, that is one way of doing it.
Again, my expertise is limited to my geographic region. I cannot speak for orthodox lawn care procedures in Atlanta.
Old 09-14-2010, 07:12 PM   #7
Rewards Points: 1,088
I think your biggest issue, besides the shade, is that your young grass is fighting with the trees for water. The trees will always win.
Your best bet is to plant drought tolerant plants in those shady areas like liriope. Or, trying putting down a few rolls of sod to see if you can get more mature grass to grow.
handy man88 is offline   Reply With Quote
Old 09-16-2010, 11:07 AM   #8
Rewards Points: 42
Thought about sod, but can't find it in this area.
Old 09-16-2010, 05:18 PM   #9
Even at HD?
Old 09-16-2010, 06:37 PM   #10
Rewards Points: 42
Don't have any HD or Lowes.
Old 09-18-2010, 11:12 AM   #11
BigJohn1980's Avatar
I agree.
BigJohn1980 is offline   Reply With Quote
Old 09-18-2010, 11:56 AM   #12
Rewards Points: 150
Water, shade, a high root system; these are all factors that inhibit propagation of new grass. Again, you will need to stick to an ongoing seeding program (spring/fall) to have grass. In my opinion, sod would not be a viable option in this situation.
Old 09-20-2010, 08:49 PM   #13
Solutions (handyman)
Rewards Points: 362
Check with local gardening suppliers about the type if seed. Some are much better than others for your area. Where I live we seed both spring and fall. this gives the seeds a chance to grow and mature plus the sedcond seeding fills in the ground a little better and chokes many weed issues.
Mark Harvey is offline   Reply With Quote
My new grass seed is growing spotty? jcigar Landscaping & Lawn Care 4 05-21-2010 01:11 AM
Lawn - Grass Seed, Weeds dankreboot Landscaping & Lawn Care 2 05-18-2009 03:28 PM
Best Grass Seed? tmcguirk Landscaping & Lawn Care 13 05-09-2009 08:28 PM
Grass seed questions..... Mikey Palmice Landscaping & Lawn Care 4 04-22-2009 09:00 PM
grass seed rcassidy Landscaping & Lawn Care 2 02-27-2009 07:03 PM
