-   -   Seed grass in fall or spring? (http://www.diychatroom.com/f16/seed-grass-fall-spring-81322/)
rusty baker 09-13-2010 10:16 AM
I have 2 places in my yard, under the shade of catalpa trees, that I can't get grass to grow. The soil was tested at the University extension center and they said it's fine. We have seeded with dense shade seed in the spring and even tho we keep it watered it dies out in August. I till and rake it before I plant. It grows like crazy til the weather gets hot. Should I seed in the fall instead? Should I put straw on top to hold in the moisture? This is in southern Missouri.
Handy Vinny 09-13-2010 10:46 AM
I would seed in both Spring and Fall, covering the seed with peat moss instead of straw. Water daily and the peat moss will keep the area moist, as well as disguise the seed so birds will not eat them.
Straw does nothing for moisture retention; at best, it is semi-effective barrier against birds. Perpetually wet straw can also propagate mold, which can kill new grass crowns and exacerbate an already bad situation.
Good luck.
By the way, it sounds like you probably need a shade mix. I use a 4-fescue shade mix when I seed for clients. It has never failed me. Go to a nursery or garden and feed shop; they will be able to help you. I might add that growing and maintaining grass under trees--especially trees with high root systems, like maples--is an ongoing battle. That is, you will probably have to do it every spring and every fall.
spaceman spif 09-13-2010 11:22 AM
I've heard fall seeding allows for better root density and depth the next year.
If not, I'd go with astro-turf. And a putting green. :yes:
Handy Vinny 09-13-2010 11:34 AM
Fall seeding is really only effective with regard to root development if it is coupled with aeration. I have never heard anything that says fall seeding alone is sufficient to developing a lawn's root system. Then again, I can only speak for my geographic area, so you could be correct with respect to a different area of the country.
AstroLawn or something artificial like that would be extreme and very expensive. And unless I missed something, there is nothing in the OP's post about golf, so a green, as you say, might be superfluous.
downunder 09-13-2010 06:54 PM
Look at this:
http://extension.missouri.edu/public...b.aspx?P=G6700
Instead of me disagreeing with other posts on here, this is from the University of Missouri. It's the same thing I would do here in Atlanta, but here it is from your area.
Good luck.
Handy Vinny 09-14-2010 04:46 PM
Originally Posted by downunder (Post 500618)
Look at this:
Good luck.
Sure, that is one way of doing it.
Again, my expertise is limited to my geographic region. I cannot speak for orthodox lawn care procedures in Atlanta.
handy man88 09-14-2010 06:12 PM
I think your biggest issue, besides the shade, is that your young grass is fighting with the trees for water. The trees will always win.
Your best bet is to plant drought tolerant plants in those shady areas like liriope. Or, trying putting down a few rolls of sod to see if you can get more mature grass to grow.
rusty baker 09-16-2010 10:07 AM
Thought about sod, but can't find it in this area.
handy man88 09-16-2010 04:18 PM
Even at HD?
rusty baker 09-16-2010 05:37 PM
Don't have any HD or Lowes.
BigJohn1980 09-18-2010 10:12 AM
I agree.
Handy Vinny 09-18-2010 10:56 AM
Water, shade, a high root system; these are all factors that inhibit propagation of new grass. Again, you will need to stick to an ongoing seeding program (spring/fall) to have grass. In my opinion, sod would not be a viable option in this situation.
Mark Harvey 09-20-2010 07:49 PM
Check with local gardening suppliers about the type if seed. Some are much better than others for your area. Where I live we seed both spring and fall. this gives the seeds a chance to grow and mature plus the sedcond seeding fills in the ground a little better and chokes many weed issues.
