Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-02-2009, 10:49 PM   #1
Question securring an existing railroad tie retaining wall
I have a 5 year old RR tie retaining wall that is five ties high and about 24 feet long. It is retaining a steep slope with about a 40 to 45 degree rise that rises about 16 feet above the top tie. The ties are pinned together with 1/2 " rebar and each tie is set back 1" into the slope as the wall rises. The concern I have is the wall is setting on a clay base and was built directly against the clay embakment. There is no drainage behind or under the wall. The wall has moved out about 5/8 " on one end over the five years. The other end is somewhat secured by an extension of the wall that is at a 40 degree angle away from the hillside. There were no dead men put in to secure the wall. How can I secure the wall without tearing it all out?
Secondguesser
secondguesser is offline   Reply With Quote
Old 07-02-2009, 10:52 PM   #2
Extreme DIY Homeowner
Scuba_Dave's Avatar
Best bet for long term is to dig out behind it & put in gravel for drainage
The slope will just get worse until it falls over
And put in some dead men while you are at it
Scuba_Dave is online now   Reply With Quote
More On This Topic
How to Use a Level
How to Use a Level by Expert Village
Hi! I'm Drew Finn here for Expert Village. We are going to talk about standard hand tools and how to use them. We are going to use levels to make sure things are either nice and level or nice and vertical or even at a 45 degree angle and how they work is... Read More »
The next part is the best part it is when you pull up the wall of the clay. So the whole process that I'm doing here is called throwing the pot I really don't know why it is called throwing the pot. In this particular section is called pulling up the... Read More »
An extension ladder comes in handy for many jobs. These extra-long ladders are used to reach high levels that a regular ladder won't reach. Transportation can be tricky. Read More »
Hi, I'm Kelli on behalf of Expert Village, I'm going to show you some tips and techniques I use to place a tail extension on your horses tail. So now that we have our braids done we are prepare to tie in our extension. A lot of your tail extensions would... Read More »
Hi, I'm Kelli on behalf of Expert Village, I'm going to show you some tips and techniques I use to place a tail extension on your horses tail. So now that we have completed our first braid we are going to move to the opposite side of the tail and we are... Read More »
Retaining wall contruction questions. Tmaxx Landscaping & Lawn Care 4 06-21-2009 10:43 AM
Retaining wall Limapapa Landscaping & Lawn Care 12 02-09-2009 05:01 PM
Replacing large retaining wall notfromaroundhere Landscaping & Lawn Care 6 12-17-2008 02:30 AM
Drainage ? for an 8' tall Retaining Wall White Elk General Discussion 19 12-04-2008 10:11 PM
Retaining Wall DIY_JC Building & Construction 5 05-21-2008 03:48 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
