Sandstone Patio With Holes - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-02-2008, 11:36 PM   #1
Sandstone patio with holes
I hired a landscaper who has done a great job-- but today the sandstone patio was put down. There are 12 two inch holes throughout the entire patio and the landscaper told me sometimes they are given sandstone with holes from blasting and it was normal? I need some advice to know how to proceed. I think it looks like second hand stone. Please help...
Lyn Steele is offline   Reply With Quote
Old 09-03-2008, 01:33 AM   #2
Kap
Mowing my life away.
.What type of pavers? Square? Octagon? Irregular shapes? If irregulars they should have been cut to avoid the holes. I never would have used the ones with holes. Unless there was a certain look we were going for, such as laid in grass as a path, with grass growing around each stone and through the holes. In that case, I would get the client's explicit consent before using the ones with holes.
I would never use them in a soli patio or path application. Can you post pics?
Kap is offline   Reply With Quote
Old 09-03-2008, 09:49 AM   #3
two inches hole is too big
For antique type look patio, cracks here or there is normal... but two inches holes are way too big if you are talking about approx 2" diameter circlular hole.... I would request the installer to replace those pavers...
but then you may need to post some pictures to verify if those holes are real big "holes" or just normal stuff...
KUIPORNG is offline   Reply With Quote
Old 09-03-2008, 06:19 PM   #4
If you requested a patio with holes then you got what you wanted. Otherwise I'd tell the guy to fix it before I'd pay him a dime. I don't care what he told you. Sounds like he got a deal on sandstone and is feeding you a line.
Shamus
Shamus is offline   Reply With Quote
slumped patio fix ?? houser Building & Construction 5 03-18-2010 06:25 AM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 05:27 AM
Should I open up my enclosed patio? diyimk Building & Construction 4 07-14-2008 12:38 AM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 10:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
