Sand - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-20-2012, 09:05 PM   #1
Rewards Points: 2,238
Sand
Buying sand to put under some bricks for a little walkway in an herb garden.
I don't need much and will buy it bagged. Do I want play sand or all purpose sand, or does it matter if I just buy the cheapest?
thanks in advance
Startingover is offline   Reply With Quote
Old 04-20-2012, 09:26 PM   #2
Ravenworks's Avatar
Sand is sand for what you're doing
Ravenworks is offline   Reply With Quote
Old 04-20-2012, 09:29 PM   #3
Don't use playsand. I've used limestone screenings with no problems but others would say use concrete sand. I'm not sure about all purpose, but it may say on the bag
creeper is offline   Reply With Quote
Old 04-20-2012, 09:48 PM   #4
Ravenworks's Avatar
Originally Posted by creeper View Post
Use neither. I have often used limestone screenings with no problems, but I think the correct thing to use is concrete sand.
Limestone sand would be the number one choice,as for concrete sand,well it's just sand it is also more round than angular.
This all depends what is available to OP
Old 04-21-2012, 08:33 AM   #5
Rewards Points: 790
If you're just using it to level a few stepping stones, I would also recommend paver base, or limestone (which you can buy bagged). Sand will be fine, but use construction grade sand, not play sand, which is too fine and will eventually move away from the stepping stones.
On the other hand, if you're talking about a paver sidewalk, you'll need a solid base, 4-6 inches of limestone with screenings (dust and fine particles) and 1-2 inches of paver sand for leveling.
cibula11 is offline   Reply With Quote
Old 04-21-2012, 02:26 PM   #6
wow, the above post sounds like I should be digging a path deeper than what I planned. Maybe I'll google "laying a brick path".
I'll be buying from Walmart or Lowes.
thanks
I remember years ago just plopping stepping stones on the ground and they would eventually sink.
Old 04-21-2012, 02:30 PM   #7
[quote=Startingover;903894
I remember years ago just plopping stepping stones on the ground and they would eventually sink.[/quote]
This time around Ms. Startingover, we do it right
fine sand in cold water line, cold water stopping then turning hot and blasting sand cstrange Plumbing 2 12-02-2011 02:19 PM
finishing paver patio - what sand? H.O.P. Landscaping & Lawn Care 2 07-20-2011 02:00 PM
Need Help - Failed Patio in Sand Install lews Landscaping & Lawn Care 5 04-19-2010 06:34 AM
Best Way to Establish Plantings Over Sand flyboy Landscaping & Lawn Care 4 04-07-2009 09:38 AM
painting sand over sand heather Painting 1 04-03-2007 10:35 AM
