Ryobi Trimmer Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-18-2008, 12:36 PM   #1
I just got a Ryobi Curved Shaft Trimmer as a gift. It comes with "Reel Easy String Head and a "Pro Cut II String Head". Could some one explain what the difference between the 2 are?
What is the best way to edge with the trimmer between mulch and grass? I've seen people do it and they make it seem so easy.
Thanks in advance for any feedback!
TTran is offline   Reply With Quote
Old 06-19-2008, 01:25 AM   #2
The "Reel Easy" is a 'bump' head. It contains a length of line that's replenished when you tap the head to the ground. The "Pro" uses a "fixed" length line. These come precut and are manually inserted into the head. It's usually heavier duty line and lasts a bit longer.
Verrrrry carefully! Safety first: eye protection, hearing protection and long pants and leather boots. Sure, you can wear shorts and flip-flops if you don't mind your legs and feet getting lacerated. Dirt and rocks WILL fly up in you face in the vincinty of your eyes and listening to any loud sound for a sustained period WILL damage your hearing. It's not worth it.
To edge, you have to rotate the head of the trimmer 90 so that it is moving vertically and away from you. Some units allow you to do this on the handle. If yours doesn't then you have to rotate the whole shebang.
By observation, you can gauge how close to go to the ground and by angling the head ever so slightly, you can, with practice get into some tight spaces. Edging will eat a lot of line.
Randell Tarin is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 10:12 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
