Running Two Lines Off One Irrigation Pump? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-14-2014, 09:15 AM   #1
Rewards Points: 219
Running two lines off one irrigation pump?
I have an irrigation pump with the intake pulling water from the lake. The output of water is tee'd coming off the pump with an 1 1/2 line running up to my yard for a sprinkler (unfinished irrigation system) on one side and a 1/2 inch line coming off the other side of the tee going to a sink and fish cleaning table. Right now, it is all ran by simply flipping the breaker to turn off and on.
I would love to put a small pressure tank on the small line to use for water to the sink but hope to add some sort of irrigation timer to the irrigation side. Can both of these be done?
bassadict69 is offline   Reply With Quote
Old 04-14-2014, 12:22 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,646
Ayuh,.... So long as the tank is 'tween the pump, 'n irrigation valve,....
'n if the pump will tolerate that back-pressure, on restart,...
Ya, that oughta work,....
Bondo is online now   Reply With Quote
Old 04-14-2014, 12:56 PM   #3
Rewards Points: 219
Second question...is there such thing as too small a tank?
Will the pump continue to run as long as the tank stays empty while irrigating? or will the pump come on, fill the tank, shut off till tank is empty, then come on to fill it back up again?
I would love to use a small 2 or 4 gallon tank...something to simply automatically turn the water on when being used.
Old 04-14-2014, 01:55 PM   #4
Oso954's Avatar
Rewards Points: 1,338
The pressure tank should never empty. The pump should keep running and be able to maintain a working pressure in the system the entire time.
If your pressure tank is too small and you have a good pump, the pump may actually hit the shut off pressure and stop pumping until some of the pressure bleeds off.
If the pump cycles too often while irrigating, it will probably shorten the life of the pump.
Oso954 is offline   Reply With Quote
Adding 1000/2000 w 240v heater to 15 amp 240v circuit running 1/2 HP well pump isaacjames Electrical 33 01-06-2014 07:31 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
Running Propane Lines to New Cooktop bcollin76 Plumbing 6 08-13-2011 11:22 AM
Cutting lines from well to pump tibberous Plumbing 0 06-27-2011 09:40 PM
ejector pump running constantly??? streetwise83 Plumbing 1 09-13-2008 08:37 PM
