Rubber Patio Pavers - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-04-2013, 05:00 PM   #1
Rewards Points: 33
Rubber patio pavers
Has anyone used these? I like the idea for my 16x16 patio because they are light and easy to install. I can't really get good info on what to do for a base for them... The same as for stone pavers? 4" crusher dust, then sand? Landscape fabric under the pavers? Glued down?
recklessrick is offline   Reply With Quote
Old 07-04-2013, 09:45 PM   #2
Rewards Points: 2,176
maybe this will help. The only negative thing I've read is the possibility of fading in direct sunlight.
http://www.ehow.com/how_7665205_install-rubber-paving-blocks.html:
sorry, my link isn't working, but you can google; "installing rubber pavers" and get lots of help.
Startingover is online now   Reply With Quote
Old 07-05-2013, 09:13 AM   #3
Rewards Points: 33
Thanks for the link!
Old 07-09-2013, 11:36 AM   #4
The biggest benefit of rubber patio pavers is its safety features. They are much more shock absorbent than stone, making them an ideal choice for patios that will be used by small children or elderly people.
leenamark1 is offline   Reply With Quote
Old 07-11-2013, 09:33 PM   #5
Rewards Points: 34
I have a few a the bottom of my (very low) deck stairs in case my toddler takes a header off them. Haven't had them long enough to comment on durability.
The bit of research I did pointed to them only being used over existing hard surfaces like patios, sidewalks... didn't se anything on use over crushed stone. If it's compacted really well I bet they'd be fine, but for the $$$ you need to be sure.
midwestcoast is offline   Reply With Quote
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
Travertine pavers driveway in cold climate Leopro Concrete, Stone & Masonry 7 01-04-2013 11:06 PM
Small Pavers vs Patio Blocks - Installation Difference snowfiend131 Landscaping & Lawn Care 7 04-17-2012 03:33 AM
Patio pavers strong enough for a car? Clemsig07 Landscaping & Lawn Care 4 06-03-2011 08:28 PM
Patio Flat Rubber Roof installed, and gutter cleaning - ripped off? mark2741 Roofing/Siding 17 03-08-2010 11:55 AM
