Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 10-16-2009, 07:50 PM   #1
rubber coating for paved backyard
Hello,
my backyard is all paved with cement. Is there a rubber coating that I can apply to the pavement to cushion it? Like the the type of rubber material that are found on track fields. My high school had a rubber track.
Other than buying outdoor rubber floor mats, are there other rubber-products that can be used on cement floors?
I don't like the rubber mats because I'm not convinced that they won't promote mold growth (i.e. water trapped under the mats).
hellomoto is offline   Reply With Quote
Old 10-16-2009, 08:05 PM   #2
sdsester's Avatar
There are rubber pavers that are quite versatile and nice. On advantage to them is that they are easy to replace if one or two get damaged somehow.
http://www.paversearch.com/rubber-pavers-menu.htm
sdsester is offline   Reply With Quote
Old 10-18-2009, 11:00 AM   #3
Don't know it all, yet!
Try searching for playground surfacing contractors/supplies in your area. There are rubber membranes made from ground tires that might work for you.
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 10-18-2009, 11:09 AM   #4
Xtreme DIY'r
I think I'd be inclined to rip most of it up if it was the entire back yard
How big of an area is this?
rubber hoses - code compliant? daixloxbmw Plumbing 10 01-07-2011 09:15 AM
Which coating to use ? desgnr Roofing 2 06-05-2009 12:00 PM
Help with repairing a flat rubber garage roof Toasty Roofing 2 07-01-2008 09:43 AM
Rubber roof prices tgf40 Roofing 4 05-27-2008 02:02 PM
Reflective Coating on Flat Roof MelindaA Roofing 3 01-05-2006 06:08 AM
