Rototiller Vs. Jackhammer - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 12:03 PM   #1
Rototiller vs. Jackhammer
We are killing sod. We are not replacing it. What is best way to get rid of that top layer? We are going to recycle some of it into a garden area.
Thank you,
Cydney King
anjaowner is offline   Reply With Quote
Old 06-15-2012, 01:02 PM   #2
MarginallyQualified
Rewards Points: 2,464
Rent a "sod cutter" to remove the grass, it's roots and the inch or so of soil there.
Once you decide that you actually do want to have a lawn again....
THEN (after you've run the chem tests on the soil) add the needed nutrients, lime, fertilizer and some extra soil into the lawn by roto-tilling it all in.
THEN rake and roll. THEN hydroseed.
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
user1007 (06-15-2012)
Old 06-15-2012, 01:22 PM   #3
Too Short? Cut it Again!
Pretty much sums up the approach! Since you will have the sod you might as well use it otherwise I would hydroseed also.
Do make sure you are ready to put the sod right back down when you cut it or it will likely die on you especially if you let it sit for a day or two. This means you have to do the soil prep in the new part of the garden before you rent the sod cutter. Water the transplanted sod as you lay it down. And roll it all with a half-full landscape roller when you are done.
Old 06-16-2012, 06:59 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,066
Thank you,
Cydney King
Ayuh,... So what's goin' into the hole yer diggin',..??
A Bulldozer would be My 1st choice of Tool...
Bondo is online now   Reply With Quote
First time using a jackhammer Red Squirrel Tools 23 06-25-2011 11:01 AM
Rototiller i.d. dpudsy Landscaping & Lawn Care 1 05-03-2011 08:43 PM
How to reclaim this area from nature? Chemicals? Rototiller? CoconutPete Landscaping & Lawn Care 20 04-27-2010 10:35 AM
Rototiller shut down econdave Tools 4 09-22-2009 07:03 PM
Will a rototiller be able to till thick mulch into my soil? joeyboy Landscaping & Lawn Care 7 06-30-2007 05:54 PM
