Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 05-12-2005, 08:45 PM   #1
Rotary Lawn Mower
I think I killed my lawn mower. I asked my son to get it ready for a cutting this afternoon I notice that the mower started ok but like 2 minutes later it made somekind of noise like there was no oil in it. Now it does not turn on at all. This is a 4.5HP is fairly new 2 years old. So now is time to open it up and see what happend to the motor. Any good technicians in lawn mowers outthere?
jarg is offline   Reply With Quote
Old 05-13-2005, 12:58 PM   #2
Mod / ArchiBuilder
Cole's Avatar
Rotary Lawn Mower
What kind of mower is it?
EDIT: Brand?
Cole is offline   Reply With Quote
Old 05-13-2005, 04:03 PM   #3
Talking
Rotary Lawn Mower
Craftsman 4.5hp
Old 05-13-2005, 06:03 PM   #4
Contractor
Rotary Lawn Mower
Have you checked the oil level? Is it manual or electric start? Can you tell who made the engine?
Teetorbilt is offline   Reply With Quote
Old 05-14-2005, 03:40 PM   #5
Rotary Lawn Mower
This a craftsman 4-cycle engine. I check the oil there was none. I have removed the fuel tank, blower housing, now I am at the flywheel. It looks like I need a special tool to remove it. I am going to get to the bottom of all this.:confused:
Old 05-14-2005, 09:14 PM   #6
Contractor
Rotary Lawn Mower
Sounds to me like the connecting rod is gone, so is the mower. Craftsman does not build engines, they re-market them.
I'm guessing that your engine is history. You should use the correct puller for the flywheel but for an already dead engine you can do the following. Back off the flywheel nut until it is flush with the top of the crankshaft. Pry up on the flywheel with a large screwdriver or prybar and smack the nut with a large hammer. You want to set up an impact, not drive the crankshaft through the bottom of the crankcase. Sharp taps with a 3# hammer ought to do it.
I think that you are on your way to a new mower but it is always fun to take something apart.
Old 05-15-2005, 03:18 PM   #7
Thumbs up
Rotary Lawn Mower
I called sears this is the retail place where I got the mower, and they sell all the parts for this particular motor. Piston, pin and assembly, connecting rod assembly, crankshaft. I could build it up my self again. Thanks for all your help everyone.
Old 05-15-2005, 05:07 PM   #8
747
registered
747's Avatar
Rotary Lawn Mower
I Had The Same Problem Last Fall When I Was Mowing My Lawn SO I Wouldn't Have To Rack The Leaves. I Have A Mulcher Mower. It Froze Up On Me. No Oil. I Put Some Oil In It. The Blade Was Still Froze Up. Got A Big HAND Held Hammer Gave The Blade A Good Whack I Was Back In Business. Now I Make Sure I Keep Oil In It. Just Mowed Lawn Yesterday With It. ITS ABOUT SIX YEARS OLD PUSH MULCHER MOWER.
747 is offline   Reply With Quote
Old 05-19-2005, 11:33 AM   #9
Rotary Lawn Mower
Open up the motor and found nothing wrong with it, the camshaft is in one piece so is the connceting rod, the piston is ok but the spark plug was burn black. The blade looks a little bend but I think I can use it for another month or so. So now is to put it back together were the challange comes in. Thanks for all your help.
Old 07-03-2005, 03:37 PM   #10
Rotary Lawn Mower
That's pretty cool. I had a similar situation about 10 years ago and just replaced the motor. Now i wish I had tried the hammer first.
David Meier
Meier's Enterprises Inc. [Pressure Washing]
Email: d a v i d @ m e i e r s e n t e r p r i s e s . c o m
Daily Tool & Computer Deals http://www.DailyTool.com
meiersenterprises is offline   Reply With Quote
More On This Topic
Ok, here we are back, I'm going to talk about starters. Different types of starters. Briggs and Stratton came out with what I think is probably the best starter and of course they don't use it anymore. But you'll see that there's a big hole in here and... Read More »
Ok, now that you've got the starter clutch off and you're going to put a new starts clutch on, very, very important that you clean the shaft of the that you're going to put the starter clutch back onto. If you don't, you're going to have exactly the same... Read More »
Hi, this section is on starter pawls and you know how the starter clutch has internal ball bearings that grab and turn the flywheel, this is an external pawl which usually will come out of the starter, engage a section of the cup that's attached to the... Read More »
Caring for a lawn mower is the best way to ensure a safe and trouble free season of lawn care. Maintaining a well-lubricated engine and keeping the blades in top shape reduces problems associated with bad timing and dull grass cutting. Use the following... Read More »
Hi, Dave Parke here. I'm going to talk about the history of starters. These little engines are great. They're fantastic, they do all kinds of jobs for you. They actually, they have a wonderful history, they started with a power wheel that drove like a... Read More »
fix my Lawn Mower Starter myself !!! KUIPORNG Landscaping & Lawn Care 10 06-28-2009 02:34 PM
murray lawn mower herbl38 General Discussion 6 04-27-2008 10:16 AM
Lawn mower question muchadu Landscaping & Lawn Care 2 04-01-2007 08:33 AM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 01:25 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
