-   -   Rotary Lawn Mower (http://www.diychatroom.com/f16/rotary-lawn-mower-603/)
jarg 05-12-2005 07:45 PM
Rotary Lawn Mower
http://www.diyrepair.com/forums/images/smilies/mad.gif I think I killed my lawn mower. I asked my son to get it ready for a cutting this afternoon I notice that the mower started ok but like 2 minutes later it made somekind of noise like there was no oil in it. Now it does not turn on at all. This is a 4.5HP is fairly new 2 years old. So now is time to open it up and see what happend to the motor. Any good technicians in lawn mowers outthere?
http://www.diyrepair.com/forums/images/smilies/eek.gif
Cole 05-13-2005 11:58 AM
What kind of mower is it?
EDIT: Brand?
jarg 05-13-2005 03:03 PM
Craftsman 4.5hp
Teetorbilt 05-13-2005 05:03 PM
Have you checked the oil level? Is it manual or electric start? Can you tell who made the engine?
jarg 05-14-2005 02:40 PM
This a craftsman 4-cycle engine. I check the oil there was none. I have removed the fuel tank, blower housing, now I am at the flywheel. It looks like I need a special tool to remove it. I am going to get to the bottom of all this.:confused:
Teetorbilt 05-14-2005 08:14 PM
Sounds to me like the connecting rod is gone, so is the mower. Craftsman does not build engines, they re-market them.
I'm guessing that your engine is history. You should use the correct puller for the flywheel but for an already dead engine you can do the following. Back off the flywheel nut until it is flush with the top of the crankshaft. Pry up on the flywheel with a large screwdriver or prybar and smack the nut with a large hammer. You want to set up an impact, not drive the crankshaft through the bottom of the crankcase. Sharp taps with a 3# hammer ought to do it.
I think that you are on your way to a new mower but it is always fun to take something apart.
jarg 05-15-2005 02:18 PM
I called sears this is the retail place where I got the mower, and they sell all the parts for this particular motor. Piston, pin and assembly, connecting rod assembly, crankshaft. I could build it up my self again. Thanks for all your help everyone.http://www.diyrepair.com/forums/imag...s/rolleyes.gif
747 05-15-2005 04:07 PM
I Had The Same Problem Last Fall When I Was Mowing My Lawn SO I Wouldn't Have To Rack The Leaves. I Have A Mulcher Mower. It Froze Up On Me. No Oil. I Put Some Oil In It. The Blade Was Still Froze Up. Got A Big HAND Held Hammer Gave The Blade A Good Whack I Was Back In Business. Now I Make Sure I Keep Oil In It. Just Mowed Lawn Yesterday With It. :) ITS ABOUT SIX YEARS OLD PUSH MULCHER MOWER.
jarg 05-19-2005 10:33 AM
:rolleyes: Open up the motor and found nothing wrong with it, the camshaft is in one piece so is the connceting rod, the piston is ok but the spark plug was burn black. The blade looks a little bend but I think I can use it for another month or so. So now is to put it back together were the challange comes in. Thanks for all your help. :)
meiersenterprises 07-03-2005 02:37 PM
That's pretty cool. I had a similar situation about 10 years ago and just replaced the motor. Now i wish I had tried the hammer first. :(
