Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-19-2010, 01:13 PM   #1
Roots pushing up bricks on patio
I have a tree, and then around the tree a brick patio.
Roots from the tree and pushing up the bricks from the patio.
What is the best solution for this?
Thanks!
abefroman2 is offline   Reply With Quote
Old 07-19-2010, 06:31 PM   #2
GardenConcepts's Avatar
Cut the roots and install a root barrier 24" depth to keep the roots from growing again under the patio. A clean cut on the roots will heal better than a ragged cut.
If you are cutting large roots - 2-3" in diameter or more- you may damage the tree. The further away the cuts are from the tree, the less likely you are to cause damage.
Chris
GardenConcepts is offline   Reply With Quote
Old 07-19-2010, 06:38 PM   #3
These are pretty big roots.
It would be difficult to go 2' down.
Old 07-19-2010, 06:40 PM   #4
Then it sounds like Roots vs. Patio, and you get to pick the winner. Move the patio or cut down the tree.
Chris
Old 07-20-2010, 11:44 AM   #5
I asked a similar question about a magnolia tree that had pushed up the concrete driveway. I didn't want to cut the only tree I have in the backyard, so I had the concrete jack hammered out and the landscaper has severed the smaller roots (1 - 1/2") about 10-12 feet from the base of the tree. I am using some of the large broken concrete as runners for the car and turning the rest into a veggie garden. It has been several days and the magnolia looks unscathed, so I think this strategy has worked. Now, water will get deeper into the soil and perhaps the roots don't have to stay on the surface.
jensu2 is offline   Reply With Quote
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Pouring Patio Slab and Post Footings Question average_male Building & Construction 17 09-27-2009 02:44 PM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 03:35 PM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 02:41 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
