Rock Stack - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 10:03 AM   #1
Rock stack
I would like to build a rock "tower" as a landscape accent. I have seen small river rock "towers" stacked with a steel rod holding them together in a stack. I want to use larger rocks from my yard. Other than drilling through them and using a rod, is there a better way or technique to adhere them together.
MikeMoe is offline   Reply With Quote
Old 06-14-2009, 07:10 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
you can use mortar mix, construction adhesive, or even two part epoxy ( the last two options work better with flatter stone)
Mr Chips is offline   Reply With Quote
Old 06-14-2009, 09:36 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
those are called ''cairns'' and have a long history
http://www.ehow.com/how_4550314_make-stone-cairn.html
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
gma2rjc (09-19-2010)
Old 09-18-2010, 05:56 PM   #4
I make a lot of small cairn's - Mike did you figure a way to build a larger one? I am looking for a way to secure the stones in a large out door sculpture
11roses is offline   Reply With Quote
Building a deck on solid rock time2scream Building & Construction 3 03-05-2009 08:45 PM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 01:11 AM
Landscaping Rock FEEPHEE Landscaping & Lawn Care 2 09-19-2008 05:47 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
