Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 02-19-2011, 11:00 PM   #1
Riding Lawnmower, Wrong Firing
I have a Murray 14hp riding mower, here is the deal, i removed all the safety switches, clutch, deck, and seat switches, it turns over, as on most engine when the engine is being tured over it is firing at the same time, well now mine fires when you let go of the key, then it backfires real loud, it is firing after the starter stops spinning, could someone help me is there a wire that needs to be somewhere
chainsawmatt is offline   Reply With Quote
Old 02-20-2011, 09:03 AM   #2
Thats a new one on me. Maybe the clutch switch is a momentary switch and is causing problems because the switch is now bypassed and cannot open or operate as it should. Just a guess.
Old 02-20-2011, 12:09 PM   #3
Could you maybe get a second opinion to make sure, could i run a wire from where the switch was to the solenoid and be okay, could i fiddle with the wiring until i get it to fire right
Old 02-20-2011, 01:15 PM   #4
Master General ReEngineer
Bondo's Avatar
Ayuh,... So what'd ya do with all their Wiring,..??
Old 02-20-2011, 06:27 PM   #5
I'm not sure if these safety switches are wired to the solenoid/relay. I'm thinking they are wired to the frame and work as a ground to not allow the engine to start. Like grounding the plug wire to the frame with a screwdriver.
What did you do with the wire ends/plugs to the switches?
When you say deck switch, do you meant theblade engage/disengage switch?
Old 02-20-2011, 08:28 PM   #6
I figured it out i remove one of the wires that i had wired with the rest now it works perfect.
Old 02-20-2011, 08:31 PM   #7
Which wire? Where?
Must have been part of kill switch by grounding out to the frame.
Old 02-20-2011, 08:45 PM   #8
I believe it was a yellow wire that was used on one of the safety switches
Old 02-20-2011, 08:49 PM   #9
Yep, bet it was.. I should have said safety switch that worked like a kill switch maybe
Tags
firing, remove safety switches, wrong firing
murray riding lawnmower will not start jamesw6777 Landscaping & Lawn Care 8 05-22-2010 03:40 PM
Murrary Riding Lawnmower Won't Start lerxstrulz Landscaping & Lawn Care 14 05-08-2010 12:27 PM
Murray riding lawnmower problem oujohnny Landscaping & Lawn Care 4 06-18-2009 02:04 AM
Murray lawnmower lvsorchid@yahoo.com Landscaping & Lawn Care 3 06-05-2009 07:18 PM
Riding Lawnmower clutch/brake whining ddodge General Discussion 3 08-25-2008 09:47 AM
