-   -   Riding Lawnmower, Wrong Firing (http://www.diychatroom.com/f16/riding-lawnmower-wrong-firing-95938/)
chainsawmatt 02-19-2011 11:00 PM
I have a Murray 14hp riding mower, here is the deal, i removed all the safety switches, clutch, deck, and seat switches, it turns over, as on most engine when the engine is being tured over it is firing at the same time, well now mine fires when you let go of the key, then it backfires real loud, it is firing after the starter stops spinning, could someone help me is there a wire that needs to be somewhere
boman47k 02-20-2011 09:03 AM
Thats a new one on me. Maybe the clutch switch is a momentary switch and is causing problems because the switch is now bypassed and cannot open or operate as it should. Just a guess.
chainsawmatt 02-20-2011 12:09 PM
Could you maybe get a second opinion to make sure, could i run a wire from where the switch was to the solenoid and be okay, could i fiddle with the wiring until i get it to fire right
Bondo 02-20-2011 01:15 PM
Ayuh,... So what'd ya do with all their Wiring,..??
boman47k 02-20-2011 06:27 PM
I'm not sure if these safety switches are wired to the solenoid/relay. I'm thinking they are wired to the frame and work as a ground to not allow the engine to start. Like grounding the plug wire to the frame with a screwdriver.
What did you do with the wire ends/plugs to the switches?
When you say deck switch, do you meant theblade engage/disengage switch?
chainsawmatt 02-20-2011 08:28 PM
I figured it out i remove one of the wires that i had wired with the rest now it works perfect.
boman47k 02-20-2011 08:31 PM
:thumbsup:
Which wire? Where?
Must have been part of kill switch by grounding out to the frame.
chainsawmatt 02-20-2011 08:45 PM
I believe it was a yellow wire that was used on one of the safety switches
boman47k 02-20-2011 08:49 PM
Yep, bet it was.. I should have said safety switch that worked like a kill switch maybe
