-   -   Riding Lawn Mower dieing out after using it for 10 mins. (http://www.diychatroom.com/f16/riding-lawn-mower-dieing-out-after-using-10-mins-79946/)
topgun129 08-29-2010 01:21 PM
Hi,
I have a Craftsman riding lawn mower tractor. I change the spark plug and oil every Spring. The issue I'm having is that it runs for 10 minutes then dies out. It sounds like something is killing the engine and making it stop. It seems like there is some issue with the spark and the firing doesn't sound right moments before the engine dies.
It has gas in it of course. If I go to restart it, it starts just fine for another 10 minutes then dies again and so forth.
Any ideas on what the problem is?
I also had the battery checked and it is good.
Thanks!
SDC 08-29-2010 02:59 PM
Originally Posted by topgun129 (Post 492808)
Hi,
Thanks!
Sounds like a fuel problem, check the filter and also clean the bowl, lots of debris can get in there.
Willie T 08-29-2010 04:33 PM
Don't forget the air filter. A clogged air filter can cause the motor to run increasingly richer, minute by minute, till it floods itself out.
DexterII 08-29-2010 05:17 PM
Also clean the fuel cap. Not necessarily a common problem, but I have run into a few where the vent was plugged, shutting off fuel flow.
Steve_P 08-31-2010 09:27 PM
check the spark after it dies. If it has good spark you can eliminate one variable. Sometimes electrical problems like a bad coil pack or condenser will show up only when hot.
Wildie 09-01-2010 06:10 PM
I'll second this suggestion. If the cap vent is plugged a vacuum forms in the tank and prevents the fule from flowing.
