Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-28-2012, 10:57 AM   #1
reuse or use new concrette?
I had a wooden fence that was blocking half of my backyard but i dug it out and removed the posts, the posts still have the concrette on them. Now this may be a stupid question and probably already know the answer but in order to put it back up i will have to remove the exciting concrette that is on it right?
Julius081921 is offline   Reply With Quote
Old 08-28-2012, 11:01 AM   #2
How old are the post? If there over 10 years old I'd replace them, Old concrete does not like to stick to new.
Old 08-28-2012, 12:35 PM   #3
sdsester's Avatar
I would break the old concrete off and check the posts for rot. You would just have to dig a bigger post hole to try to use the existing concrete collars and it will be hard to plumb and line up your posts with that mass around the base.
I used the dry method of setting post most of the time. Set your post. Add dry mix. Plumb and line the posts. Pour in water to cover.
sdsester is online now   Reply With Quote
Ceramic Tile clean up & reuse Pamwren@aol.com Flooring 1 01-30-2012 01:53 PM
Ripped up wet carpet - want to recycle (not reuse) - where? kuj0317 Flooring 3 08-29-2011 03:40 PM
Can I reuse these concrete deck posts? hugh71158 Building & Construction 11 07-09-2011 09:01 AM
Does anybody reuse wire? jobblyman Electrical 12 10-27-2010 09:04 AM
reuse black pipes nikwah Plumbing 5 10-12-2008 10:38 PM
