Reuse Old Post Holes? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 11:14 PM   #1
Rewards Points: 79
reuse old post holes?
Replacing my fence this weekend with same design/style. Can i just reuse the old post holes after i pull out the post/concrete or should i dig new ones if possible?
Dwillems is offline   Reply With Quote
Old 09-07-2011, 06:32 AM   #2
Willing to listen
Rewards Points: 223
If they are in the correct locations, and of the proper size and contour after cleaning them out then by all means I would be re-using them if it was me.
Done That is offline   Reply With Quote
The Following User Says Thank You to Done That For This Useful Post:
oh'mike (09-07-2011)
Old 09-07-2011, 07:24 AM   #3
Too Short? Cut it Again!
Absolutely so long as you clean all the debris out. You don't want water traps with old concrete rotting your new posts?
Old 09-07-2011, 08:31 AM   #4
Rewards Points: 150
When I worked in the lumberyard we broke in the greenhorns by having them go to the back lot and re-stack the post holes "They are right next to the treated fence posts!!!" lots of fun.
josall is offline   Reply With Quote
Old 09-07-2011, 11:10 AM   #5
Rewards Points: 79
Thanks. Figured i could but im trying to dot all my i's before i start this project so it goes as smooth as possible
Old 09-08-2011, 10:28 PM   #6
Registered User
Rewards Points: 5,516
Maybe I'm demoing them wrong, the hole always ends up about 30% larger as you disturb the surrounding soil......post-hole digger cuts a clean hole in most soils. If you must use concrete, add gravel in the hole before post/concrete to drain the post.
Gary
Old 09-08-2011, 11:45 PM   #7
Rewards Points: 79
Well we finished 7 posts today and have 6 left. Its working out good for us cuz the fence was 20 yrs old and the concrete crumbles so we break it up. Pull it out. And have perfect holes. Easier for us then digging new holes. There are tree roots everywhere!
2 2x12" Header - Want to remove post edro Carpentry 29 08-19-2011 12:46 PM
Modified post and beam framing question? diywengr Building & Construction 7 08-11-2010 08:18 AM
Concrete curing in post holes moneymgmt Building & Construction 5 11-19-2008 10:01 AM
