Retreadind A Copper Fitting??? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 11:13 AM   #1
retreadind a copper fitting???
I have a sprinkler head that has detached from a copper fitting on the under PVC line in the ground. the threaded end of the copper fitting is damaged and the PVC connection won't screw on. Can the fitting be rethreaded and ,if so,how?
muller is offline   Reply With Quote
Old 03-04-2011, 11:33 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Nope,... Replace it...
Sweating a brass fitting to a copper pipe jgs1951 Plumbing 8 09-26-2011 09:06 PM
stuck compression fitting on copper pipe John Malarkey Plumbing 2 05-10-2011 08:23 PM
gatorbite copper pipe fitting granof8 Plumbing 6 01-18-2011 05:19 PM
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 09:54 PM
aluminum vs copper for compression fitting pnutzhome HVAC 7 03-19-2009 04:14 PM
