Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-07-2007, 08:11 AM   #1
Retaining Walls
I need a crash course on retaining walls. I really need to know as much as possible to build one successfully. Any website containing tutorials would be very helpful or any personal experience. Specifically I need the following.
1. If building a stone retaining wall how do I calculate how much material I will need?
2. I am assuming that retaining walls are considered landscaping and not really covered or governed by most building codes?
3. A primer on building retaining walls.
tripower is offline   Reply With Quote
Old 09-07-2007, 09:57 AM   #2
concretemasonry's Avatar
Retaining Walls
In most areas, any retaining wall over 4' high must be engineered and have a permit because of the load behind it.
If you are considering a segemental retaining wall (SRW), go to the sites for Allan Block, Anchor Wall Systems, Keystone and Versalok. All have good information, examples are available across the U.S. and in many other countries.
concretemasonry is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 04:07 PM
What to fill my retaining wall with sheryl Landscaping & Lawn Care 4 09-05-2007 02:40 PM
help! my walls are troubled donnamarie General Discussion 5 08-29-2007 01:08 PM
