Retaining Wall Replacement - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-26-2012, 02:27 PM   #1
Retaining wall replacement
Hello! Newbie homeowner here who's ready to take on challenges of exterior work now that it's warm out.
I have a retaining wall (or what use to be a retaining wall) between my driveway and my neighbor's fence that's falling over. The challenge is that it's very close to the properly line and my neighbor's fence. I would like to understand what are the most economical way of repairing this wall, and make it last as this will eventually be a rental property.
Attached are some pictures of the current cinder-block retaining wall keeling over!
Thanks everyone!
mcjin1 is offline   Reply With Quote
Old 04-26-2012, 02:35 PM   #2
Rewards Points: 13,296
Looks like they just set a row of blocks on the ground and expected that to work.
It would need a footing pored, blocks morter in place with cap blocks on top of it to have worked out.
It would look better and be simpler to dig out at least 6" deep to grade out that area, add some crush and run, compact it and level it out and just lay some landscape stones. Going to need at least to layers, one below and one above grade.
Old 04-26-2012, 02:45 PM   #3
Thanks for such a quick reply!!
What should I do behind the landscape stones? There probably won't be the normal 12" of space to add drainage stones. I can also see the concrete footings of the neighbor's fence exposed - wondering if that's something I should be worried about when I rebuild the wall.
Also, there's a total of about 30 ft of wall that needs to be replaced. Is that something I should just hire a Bobcat or an Excavator to do, and if yes, how long do you think that would take?
what to do with the french drain behind a retaining wall MLMIB Building & Construction 4 04-08-2011 08:52 AM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 12:34 PM
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 10:03 PM
Retaining Wall Demolition --HOW? tdrumm Landscaping & Lawn Care 12 03-20-2011 03:32 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
