Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 03-18-2009, 11:53 AM   #1
Question
Retaining Wall repairs
We have a 4'x25' stone retaining wall. It's probably been there over 20+ years and was probably constructed without proper drainage. However, the constructions seems "loose" and the earth behind is mostly rock and ledge, so I'd guess that most of the water has found its way out over the years without causing a problem.
The problem is that the previous owners tried to make it look "prettier" by slathering cement or mortar in between all of the stones - effectively blocking all natural drainage. This winter proved to be too much for the wall - large chucks of mortar/cement have fallen off - and a few stones have popped out.
Knowing that the right way to fix it is to start from scratch, and knowing that that is not an option ($), we're looking at an the opportunity to do a bad patch job.
Any suggestions to minimize our intentional damage?
scout61 is offline   Reply With Quote
Old 03-26-2009, 07:13 PM   #2
take the rest of the concrete off (carefully) and fit the missing stones back in. I'm assuming this is a dry rubble (no concrete) was as originally conceived.
Dugger52 is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
railroad tie retaining wall david81 Landscaping & Lawn Care 16 09-02-2008 06:38 PM
Replacing Railroad Tie Retaining Wall Msfixit Landscaping & Lawn Care 2 07-24-2008 09:03 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
code for determining retaining wall height mrdol General Discussion 2 11-08-2007 03:47 PM
