Retaining Wall Paver Without Interlock - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-28-2013, 12:10 AM   #1
Rewards Points: 93
Hello. Landscape newbie here.
My wife wants a 1ft-tall retaining wall around her garden, about 15ft by 10ft. The garden is on the side of the backyard. Lawn is fairly flat. Currently the garden is surrounded by a single course of 4x4 treated wood sitting right on the soil. I don't know when the previous owner put the wood down, but a lot of it is rotted.
The blocks that she picked have no interlocking lips:
http://www.lowes.com/pd_477095-215-308290_0__
Each block is 4in tall, so we are thinking about 3 courses.
1. Is gravel and sand needed in this case? If so, how much?
2. Is glue needed between courses since there's no interlocking lips?
We are located in NJ if it matters.
Thank you in advance!!!
leungw is offline   Reply With Quote
Old 06-29-2013, 08:42 PM   #2
Any reason your going that high?
They have glue you can use. I'd do that over sand and rock seeing its a garden.
Tatertot is offline   Reply With Quote
Old 06-30-2013, 10:14 AM   #3
Civil Engineer
Rewards Points: 4,530
At one foot tall, with that type of block, you can probably get away without any drainage behind the wall, and using typical garden soil. And you do not need to glue the blocks in place. Somewhere around two feet high you need to start following manufacturer directions, and at 4 feet and higher, you are almost certainly going to need soil reinforcing fabric, unless you get into really large block with special interlocks.
As an aside, for gravity walls, a reasonable rule of thumb is that the width of the base needs to be approximately 40 percent of the height of the wall, so for a one foot high gravity wall, the base needs to be about 5 inches wide, and your blocks are pretty close to that.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
leungw (06-30-2013)
Old 06-30-2013, 08:11 PM   #4
Rewards Points: 93
Because one corner is about 4 inches higher than the opposite corner. If we do only two courses high, then it would seem too low at one corner.
Old 06-30-2013, 08:13 PM   #5
Rewards Points: 93
Thank you very much for the info.
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 05:45 PM
Retaining wall combining concrete blocks and PT lumber JEL Landscaping & Lawn Care 1 04-06-2012 09:39 PM
Retaining Wall Demolition --HOW? tdrumm Landscaping & Lawn Care 12 03-20-2011 03:32 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 01:02 AM
