Retaining Wall Height - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 08:35 PM   #1
Rewards Points: 83
Retaining wall height
Hi,
I want to replace an old RR tie retaining wall in my yard with concrete blocks like this Pavestone block sold at HD, or this Oldcastle block sold at Lowes. Both are roughly the same dimensions, and have a stated maximum height of 2' (6 courses).
However, I'm wondering if I can get away with a slightly taller wall. I'm planning to lay a base of compacted gravel, and then set the first course of blocks below grade so there is a solid footing. Then, I'd like to build up to 7 layers on top of that plus a 2" wall cap, so there would be 30" above grade. I'll back-fill most of the wall with crushed stone.
Has anyone used these for blocks taller walls? I know there are lots of retaining wall products out there that are rated for 3-4' wall heights, but from what I've seen you pay at least 50% more for materials. So, I'd really like to use these cheaper blocks. My wall will be just slightly taller than the stated maximum height, so I'm hoping I can get away with it.
Thanks,
Mark
cumak is offline   Reply With Quote
Old 05-10-2011, 09:18 PM   #2
concretemasonry's Avatar
Rewards Points: 2,566
I think you are considering the smaller mini-pavers for casual landscaping. Their recommendations are very conservative because only DIYer use them.
Anyone that makes the saml retail pavers usually offers the larger pavers IF the retailer choses to sell them.
The larger pavers can be used on engineered appication up to 40' high without and concrete footings or mortar.
Dick
When it comes to installing retaining wall block, make sure you have a good well draining aggregate behind them, no matter what the height is.
concretemasonry is online now   Reply With Quote
Old 05-10-2011, 10:46 PM   #3
Rewards Points: 83
Dick - thanks for your reply. Both places do sell the larger pavers as you indicated, but I was trying to avoid them due to cost. So, for the smaller pavers that I'm considering, their 2' recommendation is conservative so I should be okay adding 1-2 courses on top of that?
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 12:17 PM
In The Process Of Building My Very First Small Retaining Wall ricksample Landscaping & Lawn Care 3 03-19-2010 10:19 PM
Replacing Landscaping Tie Retaining Wall omnic Landscaping & Lawn Care 1 05-01-2009 06:14 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
