Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 06-20-2009, 11:49 PM   #1
Question Retaining wall contruction questions.
One side of my pole barn was built on a raised soil base. Over the last 8 years, the soil has slowly been eroding away. I have some pictures but I don't think I can attach them.
Anyway, I am trying to figure out the best option for a retaining wall. I happen to have nine 6"x8"x18' logs left over from our log home construction. I would like to use these since I need to get them out of my garage and they are free They are not treated so I would need some way to treat them for outdoor exposure to water and dirt. Does anyone know how I could treat these logs to use for the retaining wall? Also, is this even a feasible solution?
I have also considered using treated plywood with veritical support posts.
The wall would only need to be about 2 1/2 feet tall.
Thank you for any help you can provide.
Tmaxx is offline   Reply With Quote
Old 06-21-2009, 12:00 AM   #2
concretemasonry's Avatar
You are a dreamer if you think you can treat the logs to be good enough for even a temporary fix.
Even the large treaters with a big buget can only only produce reasonably "permanent" timber materials with high concentrations.
You would be better off using the logs in your fireplace when it gets colder.
concretemasonry is offline   Reply With Quote
Old 06-21-2009, 12:08 AM   #3
2 fingered typer
woodnthings's Avatar
Default I agree
There's a reason they find fossils in rocks.....they last for millions of years, unlike wood. Use a concrete block,natural stone or poured wall to retain soil and it will last. bill
woodnthings is offline   Reply With Quote
Old 06-21-2009, 10:03 AM   #4
I had considered using retaining wall blocks but I was unsure if it was a project I could do successfully. Are there some directions someone could point me to which has pictures of the process to follow?
thanks.
Old 06-21-2009, 10:43 AM   #5
To get installation instructions, go to the sites for the major licensors (Allan Block, Anchor Wall systems or Versalok). The different units units have minor variation in appearance, but the installation in pretty much the same for all. - Never use a concrete footing.
These units are manufactured by block producers in virtually every country, so you should have several in your area.
Dick
More On This Topic
Bonsai soils are very different from other potting soils that we might use in our garden or with our house plants because the bonsai is really a living tree that we keep prude and in a miniature form, we have to make some accommodations to the tree to... Read More »
Here is another reason that you might not want to use a cheaper potting soil. I believe in recycling, you might say the potting soil instead of throwing it out. This potting soil is recycled and this is some of the cheaper stuff. You can see it's gray... Read More »
Hello! My name is Grady Johnson and I'm a professional painter, and today I represent expertvillage.com. Okay, now we're going to talk about pressure washing retaining walls. Now, when you're pressure washing these little retaining walls, generally they... Read More »
Okay now we are going to start to prepare my soil mix for planting of my grass. I am going to take one part of the existing soil that I have already excavated out of the hole and put that into my wheel barrow. Because there is quite a bit of sand, I am... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
3 Retaining Wall Questions joetab24 Landscaping & Lawn Care 6 06-19-2009 03:38 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 06:48 PM
Wall - moving load bearing wall user49172 Building & Construction 0 03-11-2009 12:29 PM
Board Retaining Wall Randell Tarin Landscaping & Lawn Care 2 06-20-2008 06:45 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
