Retaining Wall Concrete Block Or Not - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-22-2013, 03:28 PM   #1
Retaining wall concrete block or not
I am building a small retaining wall (2 feet tall) and have 2 questions. 1)Can I use large basic concrete block on the base (buried) course and my stackable finished concrete blocks on the second course? The 1st course will not be seen. They are cheaper and the concrete block is more substantial than the stackable stuff. 2) I want to put a shed in front of my wall and will be using sonotubes for the footings. What distance from the front of the wall would you suggest drilling for the tubes? I want to be able to walk into the shed without a large gap between the shed and wall.
mttye is offline   Reply With Quote
Old 07-22-2013, 04:55 PM   #2
concretemasonry's Avatar
Rewards Points: 2,566
Most decent retaining wall blocks have some shear key to prevent sliding. You could have the entire layers of the retaining wall block eventually slide off the common block with a smooth top. Also, common block can settle easier because they do not have a solid bottom.
Dick
concretemasonry is offline   Reply With Quote
Tags
concrete blocks , retaining wall , shed foundation , sonotube
Concrete Block Wood Frame Flashing rjpj Concrete, Stone & Masonry 0 09-12-2012 11:47 AM
Dry-stack concrete block retaining wall? BRO931 Building & Construction 17 08-06-2010 08:53 AM
New window in concrete block wall swill777 Building & Construction 3 08-02-2010 02:28 PM
Retaining wall concrete base -- how thick? RDS Landscaping & Lawn Care 1 04-23-2010 02:10 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
