Retaining Wall Blocks Not Alligning Up - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 07:23 PM   #1
Rewards Points: 109
Retaining wall blocks not alligning up
I am installing a retaining wall flower bed and the lines are on top of each other.. Will this be a problem?
I read somewhere that they should eventually even back out, but I don't see that happening.
mchipser is offline   Reply With Quote
Old 05-14-2012, 08:19 PM   #2
Rewards Points: 14,312
It needs to be what's called a running bond.
Use a brick chisle and score a line across a block on both sides with a maul.
Keep wacking away and at some point the block will snap in half.
Old 05-15-2012, 07:05 AM   #3
Stay-at-home GC
I was thinking the same thing but it looks like he started with a running bond on the far side (2 over 1, 1 over 2) but it changed as he came around.
Something to do with turning the radius and the batter but my little pea brain lacks the Geometry skills to work it out.
I would guess you'll need to measure the offset between courses (since they seem to be the same) and cut that off of the first block in each course.
Course 2 - half the first unit
Course 3 - whole unit - difference
Course 4 - half unit - 2x difference
Course 5 - whole unit - 3x difference
Quite possible I'm talking out my hind end here....
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 05-15-2012, 09:29 AM   #4
Stay-at-home GC
Can we see a pic from the other side showing the first few blocks?
Old 05-15-2012, 09:42 AM   #5
Rewards Points: 109
This is when I first started
Old 05-15-2012, 09:48 AM   #6
Stay-at-home GC
Yup. Thought of a way to express myself better.
If you think of the face of each course as a lane on a running track, your top courses have a shorter distance to travel so they get there quicker. Hence the staggered start line on a running track.
So the question is, how much do we "handicap" each course so they all travel the same distance. You may have to cut each block through the radius to stay on your bond pattern.
This probably covered in great detail in any number of retaining wall literature
Old 05-15-2012, 10:18 AM   #7
Rewards Points: 109
I just found a video that might help my cause..
https://www.youtube.com/watch?v=74m6...eature=related
Old 05-15-2012, 11:21 AM   #8
concretemasonry's Avatar
Rewards Points: 2,654
mchipser -
Look at the situation this way -
You have a semi circle or so and each course or layer must be adjusted to allow for the different length along the wall due to the radius of the curve being shorter. Since you are dealing with a casual situation, there is no need for absolute perfection, but just an acceptable appearance for the curvature, whether it is an inside or outside curve or a continuing combination.
At the end of the curve, make sure you can have an acceptable coursing to bond with the remaining wall.
It is not like laying brick and cutting every unit to achieve absolute perfection.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Ravenworks (06-02-2012)
Old 05-19-2012, 03:10 PM   #9
Rewards Points: 109
I got most of it done.. I got the seams to line up.. I also have a curve in the back. I am planning to put another course in front of the sewer line to make a smaller stepped bed in front..
Old 05-19-2012, 03:28 PM   #10
Stay-at-home GC
Looks good. What was the final solution? Did you stagger the length of the first block in each course or did you have to cut each going through the turns?
Inquiring minds want to know.....
Old 05-19-2012, 03:49 PM   #11
Rewards Points: 109
On my last post, a video instruction, said to cut one or two per row if needed.. If you look at my second and third rows you will see two smaller blocks.. I still need to add the construction adhesive but it is almost done
Old 05-19-2012, 04:19 PM   #12
No need to cut every block since it is an irregular surface with a strong shadow and texture - not like drywall that is in a square level and plumb area.
You cannot over-think it since most of those units are used on larger and more varied applications (like 2 miles long in mountains).
Dick
Old 05-19-2012, 04:24 PM   #13
Rewards Points: 109
Dick
Right.. I only cut two, if I was doing drywall I would take way more time..
Old 05-20-2012, 11:15 AM   #14
Rewards Points: 109
Looks like I just need some fill dirt.. I had my helpers out this morning..
Old 05-20-2012, 08:45 PM   #15
Rewards Points: 109
Yea they do a lot of watching not much helping..
Here are some pics of the whole yard..
Retaining wall blocks not alligning up-image-958444542.jpg   Retaining wall blocks not alligning up-image-2880253367.jpg
Retaining wall combining concrete blocks and PT lumber JEL Landscaping & Lawn Care 1 04-06-2012 08:39 PM
Cheapest Retaining wall diy4life Landscaping & Lawn Care 15 03-21-2012 10:18 AM
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 11:17 AM
Retaining wall Hurriken Landscaping & Lawn Care 7 09-22-2009 11:26 AM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 01:22 PM
