Retaining Wall 5' X 44' - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 08:30 PM   #1
Retaining wall 5' x 44'
I hope to build a retaining wall 5' and 6' tall by 44' long.
I had hoped to build it with a concrete footer, "cinder" blocks (filled with concrete) and slate veneer - but I am wondering how big & deep the footer should be to avoid future problems. We live in Atlanta so the frost depth is about an inch.
An alternative is to use concrete blocks from a home improvement store - but I don't really like the look, and they are only intended for walls up to 3'-4'.
There is an existing retaining wall, actually part of the foundation which extends out about 6'. I would like to "extend" this wall with a 90 degree out-side turn, then 22' of 5' tall wall, then a 90 degree in-side turn, 5' of 6' tall wall, and finally a 90 degree out-sidet turn, and 17' of 6' tall wall.
Will footers 16" wide, 24" deep be sufficient?
https://picasaweb.google.com/sara.ra...all?feat=email#
Thank you
fnobus is offline   Reply With Quote
Old 07-12-2011, 10:13 AM   #2
AGWhitehouse's Avatar
That footing doesn't sound large enough. Not so much the depth, but the width. You need to account for the lateral loads of the earth pushing on the wall and that all translates into the footing system. On the link below you'll find an image of the typical sections through a retaining wall. You will need to replicate, to a certain degree, the one in the top right. Might be worth touching base with an engineer to ensure that the wall you build will outlast your desire to do it over again.
http://www.concretenetwork.com/concr...ges/scrap2.gif
AGWhitehouse is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 12:34 PM
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 10:03 PM
Retaining Wall Demolition --HOW? tdrumm Landscaping & Lawn Care 12 03-20-2011 03:32 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
