Retaining Wall - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-29-2008, 10:44 AM   #1
retaining wall
My husband is building a circular retaining wall using Versa Lok blocks. The wall is on the corner of our house and we are going to use it to landscape. The corner of the house slopes down that is why we chose to build a wall so the corner will be flat. The wall will be about 4-5 feet tall and about 7-8 feet in diameter. He laided crushed stone as a base and is filling in behind the wall with the crushed stone. He also put the fabric over the fill to hold it away from the wall. He didn't put in drainage tile and we are now wondering if he should tear down the wall and put one in. Is is necessary or will we be ok? Any information will help. Thanks
luv2hunt is offline   Reply With Quote
Old 05-02-2008, 08:45 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... You should be just Fine......
Retaining wall drainage werc Landscaping & Lawn Care 12 05-23-2008 11:43 PM
Going to build a retaining wall. Want to run my idea by you guys and gals keyser soze Landscaping & Lawn Care 5 03-17-2008 06:33 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 01:02 AM
