Restoring Crushed Stone? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 10:50 AM   #1
Dave88LX's Avatar
Rewards Points: 566
Restoring crushed stone?
The area between my house and garage is mostly all 3/8" crushed blue stone except for a ~3' perimeter out from the house and garage where there were flower beds. I want to run the stone right up to the house and garage, nix the beds (long gone). I will dig out the dirt 3-4" and fill that in with stone.
The existing stone has been there quite a few years. Filled with decayed leaves/flakes, dirt, etc. Any good way to restore the existing stone? I'm going to put a thin layer over the existing to build it up in some areas, but, I'd like to get it cleaned out.
I wish I had a screen contraption to wash the dirt/sand out of the piles of crushed stone I have sitting off to the side!
Dave88LX is offline   Reply With Quote
Old 08-12-2013, 11:11 AM   #2
Too Short? Cut it Again!
If you are willing to pull it out and rinse it off you could build yourself a little screen setup easily enough.
Could try shop vacuuming it but I doubt you will get far.
Old 08-12-2013, 11:17 AM   #3
Dave88LX's Avatar
Rewards Points: 566
I'm getting my house prepared to rent out, so I don't want to go too crazy. It'd be a rather large area to dig out and rinse, so IF I did do something like this, it'd just be for the small piles I have off to the side.
Old 08-12-2013, 11:50 AM   #4
kwikfishron's Avatar
Rewards Points: 620
Funny you bring this up but washing rocks is how I spent part of yesterday. About a yard and a half of lava rock filled with dirt I salvaged off a job.
I bought a small roll (2'x5') of 1/2" wire mesh and cut that in half (2'x2'6"). Built a 24"x30" 2x4 box and stapled the mesh to the bottom of that, offsetting the two layers for a finer screen.
I set the box on saw horses with the wheelbarrow next to that. A few shovels into the box, rinse then dump into the wheelbarrow. I went through that pile in no time.
It was a slick little system I had other than my soaking wet feet.
Next time I'll wear me boots.
kwikfishron is online now   Reply With Quote
Old 08-19-2013, 12:45 PM   #5
Dave88LX's Avatar
Rewards Points: 566
I decided to just rake it over, and blow off what I could blow off. I will throw a new inch or so over top. Screw it, it's going to be a rental house. :D
Heavy natural stone wall tile: mastic or thinset? Is drywall adequate? Minich Remodeling 8 02-01-2012 08:27 AM
Anyone have any luck using compacted crushed stone to set a fence post? nullqwerty Building & Construction 7 10-25-2011 08:21 PM
Soil under slab - No crushed stone used ges823 Building & Construction 10 09-05-2010 12:33 AM
paint textured with crushed stone. ouchmythumb Painting 5 05-12-2007 07:45 AM
