Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 07-24-2008, 12:25 AM   #1
Location: I live in a small rural community between Gr Rapids, Kalamazoo and Battle Creek, MI
Replacing Railroad Tie Retaining Wall
We have a railroad tie retaining wall that now must be replaced since we've had so much rain here in Michigan this year. We live on a lake and the retaining wall supports our upper parking area. There are 15 steps that go between 2 sections of the wall. Whoever installed it the 1st time, only did half of it right. I am trying to decide if the wall should go across the 48 ft of this area; or figure a better way of installing the steps so that we stop losing all of the soil/gravel/sand that the wall is supposed to hold back. It seems like they used pieces that were left over to do the smaller side and created planters. Don't the RR ties need to go back into the soil perpendicular to the wall itself? If so, how far back should they go? The left side is staggered, so it's hard to tell how far back in they go. Any ideas?
a frustrated Msfixit
Msfixit is offline   Reply With Quote
Old 07-24-2008, 07:09 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, the ties should return back to anchor the wall as you say.
Have you considered using forms and concrete, along with proper drainage construction?
Done right, the area can last "forever" with no decay or slumping.
- Build Well -
Old 07-24-2008, 09:03 AM   #3
ccarlisle's Avatar
Hmmm, let's see here...48 feet across, in 2 sections, separated by 15 steps up to your parking area. Say about 9-10 feet high, and say three cars in the lot...
That sounds to me like a lot of weight to hold back and IMO' - just given the height - railroad ties would not have been my first choice, given that, the creosote content of the ties (or something similar) and the proximity of the lake. Off the top of my head, I'd say a 9' high retaining wall with just grass above it, would have needed a 60 degree angle and therefore would have had to go back into the soil at least 6 feet. Add extra weight to that and to my mind, this is a temporary structure at best.
I would have rather seen a proper concrete wall, proper drainage tube, geotextile and interlocking stones in the first place -and certainly as a replacement. Hopefully that's in your budget.
ccarlisle is offline   Reply With Quote
More On This Topic
Hello everybody I am David Rodriquez, horticulturist with Texas Agri-life Extension service on behalf of Expert Village and we are going to show you some gardening steps in preparing your vegetable garden for the spring planting. A lot of people as... Read More »
How to Remove Lug Nuts
How to Remove Lug Nuts by Expert Village
Hi. My name is Nate McCullough, on behalf of Expert Village. In these clips, we're going to talk about the proper way to inspect, remove, replace, and maintenance your vehicle's shock absorbers. In this clip, we're going to talk about the service... Read More »
Install the retaining pin in the differential of your car during high-performance brake installation on a classic muscle car; learn how in this free auto-restoration video. Read More »
Hi, my name is Nate McCullough on behalf of Expert Village. In these clips we're going to talk about the proper way to inspect, remove, replace, and maintenance your vehicle's shock absorber. In this clip I'm going to talk about your replacement shock... Read More »
Hello! My name is Grady Johnson and I'm a professional painter, and today I represent expertvillage.com. Okay, now we're going to talk about pressure washing retaining walls. Now, when you're pressure washing these little retaining walls, generally they... Read More »
Retaining wall Hurriken Landscaping & Lawn Care 7 09-22-2009 12:26 PM
railroad tie retaining wall david81 Landscaping & Lawn Care 16 09-02-2008 06:38 PM
retaining wall luv2hunt Landscaping & Lawn Care 1 05-02-2008 08:45 PM
Going to build a retaining wall. Want to run my idea by you guys and gals keyser soze Landscaping & Lawn Care 5 03-17-2008 06:33 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 01:02 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
