| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
What Type of Lumber to Use in Framing a New Wall in your Garage
by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about buying lumber. Here I have two different types of lumber. This piece of lumber is treated and this piece of lumber is untreated. You know that it is treated because... Read More »
How to Sculpt Concrete
by eHow.com
You can make interesting objects for your garden and walkways with concrete sculpture. Concrete is readily available and you can make all sorts of simple objects from it. The following directions show you how to sculpt a bas-relief concrete decoration. Read More »
How to Set up a Hamster Cage
by eHow.com
The most common type of hamster cage is a wire cage with a plastic base. Glass aquariums also work well for housing hamsters. If using a glass aquarium, make sure the top of the aquarium is made from wire and provides good ventilation. The cage needs to... Read More »
How to Store Hay
by eHow.com
Hay is a necessary items in those parts of the country that do not have the benefit of temperate weather all year round. Hay, when stored properly, can feed your horses and cows nutritious food even in the dead of winter. Storing your hay properly is... Read More »
How to Buy Wood for a Deck
by eHow.com
A new deck may be just the addition your home needs. Patios are perfect for relaxing evenings, backyard barbeques and family gatherings. The process of constructing a deck can be time-consuming and expensive, especially when it comes to buying the lumber... Read More »
