-   -   replacing cedar fence post (http://www.diychatroom.com/f16/replacing-cedar-fence-post-16443/)
Wendy2 01-31-2008 03:13 PM
One of my fence posts, set in concrete, was rotten so we pulled it out without damaging the concrete. Is it possible to successfully place a new post in the old slot in the concrete? A new one should fit but I'm not sure whether it would be tight enough to not wobble and get out of line. Any ideas?
Randell Tarin 01-31-2008 05:15 PM
IMHO, it would be best to remove the old concrete and set the new post with fresh. Barring this, you might try adding some cedar shims between the concrete and the post. This might tighten it up.
Tscarborough 02-01-2008 02:24 PM
Did it occur to you why the previous post rotted?
concretemasonry 02-01-2008 02:30 PM
Get rid of the concrete and put a new post in new concrete. This time, keep the top of the concrete slightky above the ground level and slope the top to shed water.
Wetting and drying is the cause of most wood rot and generally occurs right at ground level. Above and below the concrete, the moisture content is quite uniform as long as the wood cannot wet and dry from the soil esposure.
ididit 02-03-2008 01:10 PM
If the hole is deep enough ad about 6" of loose gravel in the bottom first. then wedge the post in with cedar or tp shims. The gravel will give the water a place to go away from post. Most new wood post are set with just gravel all around.
