Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 08-11-2011, 09:32 PM   #1
replacement trimmer head
My previous post detailed my frustration with my gas trimmer having the line continually jam and snap in the spool. Further research shows I am not alone. So I am now looking at a replacement head, but there are a number of options, so I need some feedback. I have seen one by aero-flex that uses helicopter-like blades, and another named "hassel-free head" that uses 8" pre-cut lines. There are several more similar and all cost around $20-$25. I need something that can withstand an occasional strike to concrete edging and sidewalk without snapping. Any suggestions? Thanks!
Steveromo is offline   Reply With Quote
Old 08-12-2011, 08:13 AM   #2
There should be a hole in the collar directly above the head. Rotate the head until that hole aligns with a second one in the housing then insert a small screwdriver to lock the arbor. If a curved shaft trimmer, turn the head to the left to loosen, if a straight shaft, turn to the right.
Lukas R.
New Mexico Topcon Paving Dealer
lkrichardsons is offline   Reply With Quote
Trimmer Revs but Head won't spin leichte Landscaping & Lawn Care 1 06-21-2011 04:16 PM
Clipped Head v. Full Round Head Nails RickT Carpentry 10 11-18-2010 10:00 AM
Shower head replacement zachg Plumbing 10 01-24-2010 09:21 PM
ceiling tile replacement around sprinkler head LanterDan General Discussion 4 10-29-2009 07:39 PM
Taco Valve Control Head Repair, or Replacement? s0lidgr0und HVAC 3 10-08-2008 12:10 AM
