Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 09-27-2010, 11:38 PM   #1
Replacement of 3 rotted railroad ties in wall system
Is there a way to replace rotted 6x6 railroad ties throughout a rr tie wall system without taking wall down? My wall system is 6 foot high and about 25 foot long in back yard. One rotted tie is at bottom and two in the middle on opposite ends of system. The tie at bottom is so rotted, you can see spikes......Need suggestions desperately!!!
nailermen is offline   Reply With Quote
Old 09-28-2010, 08:40 AM   #2
If you are lucky you can wedge up or jack up the ties above so the rotten one can be slid out or chipped out and a new one inserted, perhaps as two or three pieces.
More likely the entire tie wall has sagged as the tie rotted so there isn't enough space to insert a new one.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
nailermen (09-29-2010)
Old 09-28-2010, 08:51 AM   #3
Civil Engineer
Given that your wall is six feet high, it is likely that there are perpendicular railroad ties (cross ties) in your wall. Since you can see three rotten ties on the face, there may well be rotten cross ties, which would be hidden from view. There is no easy way I can think of to determine how many cross ties are rotten, and there is no easy way to remove cross ties without taking down the wall.
If you end up removing the entire wall, you may want to consider rebuilding using segmental concrete block. I just built a small block wall in my backyard, it goes up very quickly, and the concrete will probably last a hundred years or more.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Rotted floor joists and wall edge Jim F Off Topic 2 03-09-2010 10:37 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
