Replace Rr Tie Wall With Concrete Blocks - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-22-2011, 11:43 PM   #1
Unhappy
Replace rr tie wall with concrete blocks
We're replacing our rotted landscape timber retaining walls and not sure where to start. There are two tiers and they are only about 30 inches high and even lower in other areas. The top tier is only about 26 inches tall. It is a fairly long wall though, about 42 feet. Should we remove the rr ties at the bottom level first and then dig, sand, level, place foundation blocks. Will the dirt stay back? Should we remove some of the dirt first and then remove the landscape timbers? Help! Not really sure how to start this project.
goforit is offline   Reply With Quote
Tags
cement block walls , replace retaining wall , retaining wall
Resurfacing Concrete interior wall daltinator Building & Construction 4 05-24-2011 06:04 PM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 12:06 PM
What should be the labor for constructing a dry wall with concrete blocks ? malhotrarm Building & Construction 6 03-01-2011 08:10 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Joining poured concrete and concrete blocks ws450r Building & Construction 3 12-31-2009 06:05 PM
