Replace Handle On Shovel - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-07-2014, 05:57 PM   #1
Rewards Points: 876
Replace handle on shovel
Hi;
I have a garden shovel that I use for ice and snow removal, but the original handle is too short to allow use without bending. I bought a longer (46") handle as a replacement, but am having trouble removing the old handle (which is not broken).
I removed the single rivet, but I am unable to remove the handle easily. I was trying to work in the basement where I don't have a workbench or a vise, so I was just standing on the shovel and trying to coax the handle out.
Obviously, this is going to take a lot more force than I have attempted so far, but I also believe there is some glue on the handle shaft that is keeping it tight.
I briefly tried spreading the "neck" of the shovel where the handle is inserted, but it would not open at all, and I was afraid I would break it, or worse - hurt myself trying to do this.
Watching a YouTube video, the guy has the shovel clamped into a vise, and the handle comes out easily. So is that all I need to do? Just clamp it, and pull/wiggle it out?
Not having a vice might be a problem, but I do have a couple large C clamps I can use.
Thanks for your help
FW
Ultrarunner2017 is offline   Reply With Quote
Old 02-07-2014, 06:06 PM   #2
Rewards Points: 13,468
I would not waste my time, buy one like this your back will thank you.
http://www.bing.com/images/search?q=...lectedIndex=94
Old 02-07-2014, 06:26 PM   #3
Rewards Points: 84
If it were broken or cracked, you can cut it off as close as possible with a hand saw, drill a few holes in the stub, and chip it out. But, since it's not broken, and considering that you can usually buy a complete shovel within a few bucks of a handle, I'm with Joe. Whether one like he linked or a different one of your choice, hold onto what you have, take the handle back, and buy a complete shovel. Again, you're most likely not going to spend enough more to even pay for a burger.
The Following User Says Thank You to DexterII For This Useful Post:
gregzoll (02-07-2014)
Old 02-07-2014, 09:14 PM   #4
Rewards Points: 876
That's a nice snow shovel, but what I need this one I am trying to modify is for ice chopping. I use the snow thrower for the really heavy stuff, but it won't remove ice of course...the shovel (which is actually a garden spade) does very well as is, but with the short handle it is hard on the back when shoveling. I have been just using the short one for chopping, then the snow shovel (with longer handle) for picking up the ice I have chopped, but it is more convenient to use the one shovel for both purposes.
I saw one YouTube video where a guy just pulls the handle out - ha ha. Then I read a post on another site where the guy explained it a bit better. you have to hang the shovel over a masonry wall and punch the handle out from the bottom using a hardwood dowel and a hammer.
I think that would work - at least worth a try. If I can't accomplish this within a reasonable time, I will return the handle and try to buy a shovel with a longer handle. But at this time of year, the selection of garden shovels is not good.
What I am using this shovel for is not its intended use, and it is quite possible that I am ruining it by chopping ice with it. There are much better tools for that purpose - but they all lack the shovel, so it's a two-tool process to chop, then remove the ice.
FW
Old 02-07-2014, 10:38 PM   #5
Rewards Points: 1,010
With tension applied, heat the shovel with a torch to expand the steel.
Old 02-07-2014, 11:47 PM   #6
Rewards Points: 6,652
For chipping Ice, I use a scraper made for that. For scooping any loose Icy material, I use the same type of shovel, but i went to a local Farm & Home store for the one I have.
Old 02-08-2014, 08:13 AM   #7
Rewards Points: 876
Well, after making a reasonable effort to remove the old handle, I have decided to abandon the project. I replaced the rivet I removed with a 1/4 nut and bolt, so the shovel is 100% usable as-is. I will just return the handle I bought, and see what other options are available.
I do have a cheap ice chopper, but it is not very strong, so perhaps I'll just buy a better one. Or maybe just wait for spring
FW
Old 02-08-2014, 09:16 AM   #8
Keep the handle. You may end up with a tool that you need it for. My Ice Scraper is pretty heavy duty, about five feet tall. I got it at one of the local Farm & Home stores. Actually I buy pretty much all of my tools, extension cords, tie downs at the Farm & Home store.
Better tools & equipment, local ownership, and better prices. I think I found it. It is a Ames/True Temper (Made in America, good quality steel. http://www.amestruetemper.com/search/index.aspx?q=ice Ames owns quite a few companies, so go through their links at the top, and you will find out that the different brands, are the same tool that Ames brands under the True Temper brandname.
Old 02-08-2014, 09:18 AM   #9
Here are some other Ice Choppers & shovels. http://www.amazon.com/s/ref=nb_sb_no...Aice%20chopper
Old 02-08-2014, 09:42 AM   #10
bbo
My favorite show shovel. works good as a scraper to get under packed snow and ice.
replaceable blade. I'm on year two, will probably need to get a new blade next year.
http://shop.yo-hoqualitytools.com/pr...&categoryId=32
bbo is offline   Reply With Quote
Old 02-08-2014, 04:47 PM   #11
I am about due to get a new shovel bbo. We have a plastic one, with a metal Z style bar, that the plastic shovel is all chewed up. I only use it for quick cleaning of the walkways.
When the ice starts loosing up, I use one of these (not this exact model, just one that I have had for about twenty years, that became the Winter Ice scooper. I have a good quality one, that I use for moving Earth back into holes, that does not get used in the Winter).
Old 02-09-2014, 11:45 AM   #12
bbo
Coal shovel !! I have one too, seldom use it now that I have the other one. its just not big enough for me.
Old 02-09-2014, 01:15 PM   #13
Easy for loosing up ice on the drive, so that I can have my son scoop it with the snow shovel.
Old 02-09-2014, 01:21 PM   #14
Rewards Points: 3,789
Assuming it wood, we always burnt them out with a torch. Once the wood chars a bit it tends to shrink. This is an outside activity.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 02-10-2014, 07:50 AM   #15
Rewards Points: 876
After trying different methods, and having no luck with removing the handle from the shovel, I think my best bet is to use two tools; one for ice chopping, and the other for shoveling.
On Saturday, I went out to clear a path through the ice/snow in the backyard to the compost bin (where we throw whatever scraps can go in there). Rain had fallen after the snow, then it all froze solid. No chance to shovel it. I started with the standard ice chopper, but quickly realized that the shock caused by my chopping went all the way to my neck and head, and I didn't like that at all. I know there are ice choppers with shock absorption devices, and now I think that's not a bad idea - if it works.
I ended up chopping with my ice axe (a mountaineering tool), which was a lot of work, but it does a nice job, and doesn't transmit the shock to my spine and head. Chipping that path, about 20ft long by 3ft wide took em over an hour. I think I now have a better appreciation for those mountaineers who have to chop out platforms in the ice for sleeping. And when at high altitude, the task becomes much more difficult and time consuming.
FW
lazy toilet handle Startingover Plumbing 5 05-27-2012 06:10 PM
how to replace a section of CAC duct in wall? diy'er on LI HVAC 5 03-12-2012 12:16 AM
when to replace chimney marchaels Building & Construction 2 09-07-2011 07:36 PM
Replace or sister floor joists WillK Building & Construction 6 03-09-2011 08:55 PM
Faucet handle repair margiecw Plumbing 1 11-14-2010 09:24 AM
