Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 11-07-2009, 09:28 PM   #1
Default repairing irrigation system
I recently moved into a home where the existing irrigation system was damaged when they repaired the septic system. I had water that was flowing out of the top of the ground and none of the sprinklers was working in this particular zone. I dug up and found the pipe had been cut completely off. I then tried to locate the pipe it was connected to. Appoximately 10 feet away I found another pipe however it was smaller in diameter. Is this common, or does it have something to do with the water pressure.
rpsally777 is offline   Reply With Quote
Old 11-08-2009, 05:38 AM   #2
we typically run 1" or 3/4" feeds from the zone valve and then reduce to 1/2" for the sprinkler heads. Or you may found a spot where the main line branches to several sprinkler heads with a tee fitting and you only found one so far. Connect the two ends you found and see what works and what does not work.
More On This Topic
Hi this is Fernando we are here with Expert Village and we are going over a sprinkler system and particularly we are going over laying out your pvc before you actually get started. It is very important that you take the time to layout your materials as... Read More »
Hi this is Fernando and we are here with Expert Village and again we are going over a watering system and particularly we are go over how much material you need to buy. Now out of the sprinkler, pvc piping, connectors how do you figure out what you need... Read More »
I'm Cathi Pare, with water resources in Santa Barbara speaking to you today with expertvillage.com and we are actually looking at drip systems right now and maintenance you can do as a home owner. One of the first things you are going to do before your... Read More »
Hi this is Fernando and we are here with Expert Village we are going over how to create a water sprinkling system and specifically creating trenches that your pvc piping would need to lay in. Here you could see the different areas of the yard that has... Read More »
How a Sprinkler Head Works
How a Sprinkler Head Works by Expert Village
Hi I'm Fernando with Expert Village going over how a sprinkler head actually works and as you can see this sprinkler is connected to the pvc piping. When the pressure comes from the valve which is the water rushes in and fills up the piping it then goes... Read More »
new system install.....questions firedogut HVAC 4 10-04-2009 09:10 PM
landscape irrigation system drip tubing remodelingagain Landscaping & Lawn Care 26 08-19-2009 10:17 AM
Whoa, how much water can my irrigation system use??? J187 Landscaping & Lawn Care 19 11-10-2008 05:04 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 09:32 AM
Using my gutters as an irrigation system for landscape beds? joeyboy Landscaping & Lawn Care 7 07-29-2007 12:13 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
