Removing A Tree Stump - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 09:01 AM   #1
Rewards Points: 117
removing a tree stump
a tree fell over in a friends yards. we are cutting up the tree for removal
(actually we are using the cut tree as firewood)
anyway, we arent sure how to move the root or how to dispose of it.
other then hire a tree service can anyone suggest what to do with them?
echobravo is offline   Reply With Quote
Old 02-01-2013, 10:09 AM   #2
Rewards Points: 258
bon fire?
redman88 is offline   Reply With Quote
Old 02-01-2013, 10:14 AM   #3
"You can do anything"-Mom
brockmiera's Avatar
My neighbor likes to core drill a few holes and pour in a little lighter fluid. It will slowly burn from the inside out.
brockmiera is offline   Reply With Quote
Old 02-01-2013, 12:08 PM   #4
47_47's Avatar
Rewards Points: 50
Be careful when cutting. The stump may want to stand back up or roll when you get the weight off of it.
If you can burn, drill some holes and fill them with kerosene. Keep soaking every week for about a month, then burn.
47_47 is offline   Reply With Quote
Old 02-03-2013, 11:32 PM   #5
yap that`s the thing you should do you just burn it and when it is burned then you can bury it by sand so that the insects could clean it up..
paulsmith544 is offline   Reply With Quote
Old 02-04-2013, 06:41 AM   #6
DIY staff
Rewards Points: 7,174
That stump is not very large----I think you could knock off most of the dirt and cut it up
Burning out a stump can irritate the neighbors---and should be the last resort
Old 02-04-2013, 07:18 AM   #7
Rewards Points: 1,008
Stumps and roots take for ever to dry and then don't burn well if that was even an option. Being in the yard I would think a garden hose and water is available so knock off what dirt you can and wash the areas to be cut to preserve the chain. Cut it into manageable pieces the trash service will take and be done with it.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
oh'mike (02-04-2013)
Old 03-11-2013, 11:36 AM   #8
greetings from Bolivia
harrymontana's Avatar
Send a message via Skype™ to harrymontana
burn or put it in a hole somewhere and use the access ground for some other project?
harrymontana is offline   Reply With Quote
Old 04-05-2013, 06:48 AM   #9
captainawesome's Avatar
All you need is a couple diesel trucks and some determination!
captainawesome is offline   Reply With Quote
Old 04-06-2013, 10:45 PM   #10
Rewards Points: 308
If you drill holes do it so they won't fill up with rainwater. That will just waterlog the stump and it will not rot or burn down.
puttster
puttster is offline   Reply With Quote
Old 04-06-2013, 11:38 PM   #11
Plumber
TheEplumber's Avatar
Rewards Points: 568
Several years ago my brother thought he'd burn a stump- fire smoldered down through the roots and soil and eventually resurfaced further away causing a fair amount of property damage.
Since then- I've never considered burning a stump.....
Old 04-07-2013, 12:01 AM   #12
Rewards Points: 626
Back in the day when it was legal to do. Stuff old tires under stumps and light em on fire did not matter how wet they were. Those were the days I sware I am shocked I made it this far.
Nailbags is offline   Reply With Quote
Old 04-07-2013, 10:37 AM   #13
Rewards Points: 236
yeah, i had many of those days.
Fix'n it is offline   Reply With Quote
Tree Stump joeg679 Landscaping & Lawn Care 20 01-21-2013 08:54 PM
removing tree roots from sewer tile 4just1don Plumbing 4 09-10-2010 07:23 PM
How to prevent tree stump from rotting? Jeremy Hillary Boob, PhD Landscaping & Lawn Care 8 06-21-2009 08:16 AM
Removing a tree stump that has grown into a fence brokenhammer Landscaping & Lawn Care 7 01-26-2009 10:32 AM
Tree stump mdlbldrmatt135 Landscaping & Lawn Care 2 06-16-2006 01:31 PM
