Removing Old Grass With Tiller? - Landscaping & Lawn Care - Page 3 - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 02:10 PM   #31
Rewards Points: 282
Originally Posted by sdsester View Post
Obviously soil prep, rototilling, etc. has to happen with whatever you do first but you are obviously on to this concept. Where are you? You do not want to be forcing sod to take, hydroseeding or whatever if it is so cold the plant material will be scared?
You wlll love the concept and be the envy of your friends with the hydroseeding concept.
I am from Los Angeles area, Zip code - 91741. Can hydroseeding/Mulching be done a novice, just like me..
cprao is offline   Reply With Quote
Old 01-06-2010, 05:45 PM   #32
Too Short? Cut it Again!
Sure, I suppose you can rent the equipment and the materials but hydroseeding contractors I use are so inexpensive I would not think about it.
Old 01-06-2010, 06:16 PM   #33
Rewards Points: 282
Ok. Let me contact them and see hou much it is going to cost me ..
Old 09-04-2012, 12:46 PM   #34
So what was the result? I am struggling with the same things, alot of weeds and bad grass in my backyard and was advised to use a tiller. I want to start the project this week and was interested to see what worked for you and what didnt. Did you also use the chemicals as we are trying to avoid that route.
odbarret is offline   Reply With Quote
Old 09-04-2012, 12:47 PM   #35
So what was the result? I am struggling with the same issue, alot of weeds and bad grass in my backyard and was advised to use a tiller. My concern is the tiller will replant the weeds and bad grass. I want to start the project this week and was interested to see what worked for you and what didnt. Did you also use the chemicals as we are trying to avoid that route.
Old 09-04-2012, 03:03 PM   #36
Rewards Points: 282
I did use the tiller but in the later part. A nursery guy suggested me the following process.. long and tedious but worked for me.
I manually plucked all the weeds. Then I kept waterng the area for 3 weeks on the dirt. As new weeds comin up and I was plucking them out with roots. But as the time passed, the weeds generation is slow to nil. It means all the weeds are gone..
Then I did rototilling with some topsoil and amendements.. Here Rototilling is to mix the soil with amedments. Then I laid down sod..
It worked for me.. I have NOT used any chemicals.
Old 05-08-2013, 02:26 PM   #37
do not use any grass weed killer
if you do this all concentrate grass weed killer will kill everything but you will not be able to put any sod down for 4 months because it will die because it had soaked into the ground especially the roundup concentrate the expensive kind you will just waste alot of money till the land loosen it up remove weeds before hand with a shovel then prep and plant
kylebazzell is offline   Reply With Quote
Smoke or steam coming from grass Holt Landscaping & Lawn Care 0 11-05-2009 10:53 AM
Alternatives to Monkey Grass? (Mondo grass) Carssson Landscaping & Lawn Care 5 06-22-2009 12:37 PM
Lawn - Grass Seed, Weeds dankreboot Landscaping & Lawn Care 2 05-18-2009 02:28 PM
crab grass and new grass mike4 Landscaping & Lawn Care 10 04-14-2009 03:31 AM
Swapping grass varieties... opinions? joeyboy Landscaping & Lawn Care 5 03-11-2008 08:06 PM
