Removing A Forsythia Bush ? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-16-2011, 07:39 PM   #1
Removing a Forsythia bush ?
I need to remove a large forsythia I would like some tips on what would be the best way to do this Thanks
ants1929 is offline   Reply With Quote
Old 06-16-2011, 10:18 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
They are so pretty in the spring. You can cut it back, maybe you could keep it as a smaller bush?
If you want to get rid of it, wait until spring, just after it fully leafs out, then cut it to the ground, repeat as necessary. Then physically remove as many roots as possible.
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 06-17-2011, 03:17 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 498
Hook one end of a chain around it, the other aroung the axel of your'e 4 wheel drive and pull.
The Following User Says Thank You to chrisn For This Useful Post:
jamiedolan (06-17-2011)
Old 06-17-2011, 04:30 PM   #4
A Little Of Everything
Rewards Points: 1,364
The axle?
DrHicks is offline   Reply With Quote
Old 06-18-2011, 04:52 AM   #5
chrisn's Avatar
Rewards Points: 498
I was kidding
Old 06-18-2011, 08:10 AM   #6
I am removing because I am installing a kids swing set were it is now and would like to remove most if not all the roots I was thinking may be a heavy ax should do the trick
Old 06-18-2011, 08:44 AM   #7
KemoSabe
loneframer's Avatar
I'd go with the chain and truck idea, only don't use the axle. The tow hitch would be acceptable though. I've removed many a shrub in my yard by pulling them out.
If you soak the soil well before hooking up, many of the roots will come with it. Drop a soaker hose around the base and out to the drip zone of the shrub. Let it run over night and you should be good to go in the morning.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 06-18-2011, 06:08 PM   #8
chrisn's Avatar
Rewards Points: 498
I really did not use the axle, but attached it to the frame of my Jeep and pulled out a whole hedge of yew bushes a couple years ago. Granted, I did need to chop the heavy roots with an ax first but for the most part they pulled out pretty easy.
US President to address the country unscheduled on a Sunday night. Leah Frances Off Topic 87 05-09-2011 06:33 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 10:49 AM
Removing large evergreen bush Mr. Michael Landscaping & Lawn Care 9 06-19-2008 06:26 PM
Did the bush cause the damp? atomicpig General DIY Discussions 9 02-13-2007 07:00 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
