Removing Big, Old Juniper Bushes - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 03-20-2008, 01:05 PM   #1
Question
Removing big, old Juniper bushes
My wife wants to clear out our front yard of all the juniper bush. The largest trunk is about 8" diameter at the base, and about 4' high, spreading about 10' wide.
Do I need to completely up-root these suckers, or can I just chop them down and stump-grind or burn the stumps?
They take up 2/3 of our small front yard, and we need more room and some more eye appeal.
Any help is appreciated!!
I ask the stupid questions.....but I expect the smart answers.
Wanttodoitright is offline   Reply With Quote
Old 03-21-2008, 05:57 PM   #2
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
I have those front and back in my new house. I'm severely allergic to them, but got brave and trimmed a couple. I don't think there's much to the roots. I'm thinking about wrapping a chain around them and pulling with the Jeep. Then again, I don't think they've been there too long. I know I've been chopping stray roots 15-20 feet away. I don't think they grow that deep.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 03-22-2008, 12:02 AM   #3
What a great use for my Jeep which is just sitting around lately!!!
Genius.....maybe.
Old 04-29-2008, 02:34 PM   #4
Your project sounds awesome! Before you start though, don’t forget to call 811 to make sure there aren’t any utility lines where you’re digging. It’s important to call before starting any project that requires digging, like removing tree stumps. Check out our site for some more info: http://www.call811.com/
call811beforeyoudig is offline   Reply With Quote
Old 05-01-2008, 03:12 PM   #5
Cut off and haul away everything above ground to get it out of your way. Cut around the roots with a sharp spade.Then dig or pull out the roots. Junipers are fairly shallow rooted. I think you'll find that they will come out easier than you would have thought. That has been my experience and i've removed LOTS of them.
white29 is offline   Reply With Quote
Old 05-21-2008, 09:19 PM   #6
I finally got around to trimming and chain-sawing some of these suckers.
It looks like an axe might be my best friend, now that I'm down to the stumps. I started with the smallest ones, of course!
Old 05-22-2008, 06:41 AM   #7
Yep, get rid of everything but the stumps ,expose the roots and cut them up with a sharp axe. Again,I think you'll find it easier than you think. Even big junipers that have a lot of roots come right out,the roots are pretty shallow and wide.
removing panel board from behind backsplash MJ1 General DIY Discussions 3 11-18-2007 09:42 AM
Removing painted popcorn texture from ceiling cnielsen4130 Remodeling 8 10-07-2007 11:21 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 11:53 AM
removing knockdown texture K_I37 Painting 7 05-07-2006 01:23 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
