Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care
Old 01-31-2013, 06:10 PM   #16
Removing above ground cement barrier
If someone did not pore a proper footing and the wall is tipping then there'a no since adding more on top of it, only going to make it tip faster with more weight.
Old 01-31-2013, 08:01 PM   #17
Okay so 1st image is of the "worst" part of the wall. Second and third pics are there to try and show how it connects to the driveway. And fourth pic shows length
Removing above ground cement barrier-image-1311284994.jpg   Removing above ground cement barrier-image-135146849.jpg   Removing above ground cement barrier-image-548311516.jpg   Removing above ground cement barrier-image-3254110367.jpg
Deaner13 is offline   Reply With Quote
Old 01-31-2013, 11:02 PM   #18
"You can do anything"-Mom
brockmiera's Avatar
It looks like someone built up a block wall on top of a curb. I bet its the same size curb as it is on the opposite side of the driveway.
brockmiera is offline   Reply With Quote
Old 01-31-2013, 11:12 PM   #19
After looking closer at it, it seems it would be easy enough to knock down. But then lies the issue with building some sort of water control system.
All seems like a big job. But the contractor I had quote me for a fence said $3000 so I'm looking for a DIY option haha.
Old 02-01-2013, 10:45 AM   #20
brockmiera's Avatar
3000 for a fence huh!?!? I built a nice one this summer in my backyard. It cost me about $12.50 / l.f.
If it were my place I'd remove the loosest parts of a small section and see how it is constructed all the way down. It looks like someone put a wall on top of the concrete curb that was likely there when the driveway was originally placed. They used those steel angles to try and reinforce the new concrete wall that they put up.
If it indeed was built in two stages I'd remove all of the top courses, leaving the bottom 4" of concrete there for not only water retention but also to anchor your fence posts to.
Old 02-01-2013, 01:35 PM   #21
My suggestion is to use the existing block wall to support a fence. The fence posts could be 2x4 instead of 4x4 with the metal posts in the block wall used to fasten the posts. This could take a ledger board on top of the block wall. I would fasten the end post to the garage wall, and dig another post hole at the end of the block wall to anchor that other end of the fence. The fence would not set on top of the block wall, but go to the driveway leaning against the block wall. This would cost a lot less than $3K.
Gary
gobug is offline   Reply With Quote
Old 02-01-2013, 03:47 PM   #22
Gary
This seems like a very reasonable option. From what I have calculated out so far it would cost about $550 in material (for pre-fabed pannels) and the labor would be no more intensive than screwing the panels to the 2x4's (or whatever sized wood would be flush with the wall)... Seems like a completely viable weekend project to me.
Old 02-04-2013, 12:27 AM   #23
i suppose you should contact a proper contractor so that you will take no stress and let the do their work..
paulsmith544 is offline   Reply With Quote
Old 02-05-2013, 03:14 PM   #24
Is that wall a retaining wall to keep the ground and the driveway from breaking up and falling into the neighbor's property?
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 02-05-2013, 03:16 PM   #25
Alan
It does not have any structural purpose that I can see. It is built on top of the retaining wall that is meant to keep my property from become my neighbors property.
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 11:58 PM
Removing Linoleum to lay tile over cement floor - Need some advice dgeorge Flooring 10 10-23-2010 02:47 PM
Removing Paint From Cement simplyblooze Painting 3 08-14-2010 09:44 AM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 05:02 PM
Removing a cement step on outside of house Vikeologist Building & Construction 5 06-18-2009 01:33 PM
