Remove Sand Before Seeding Or Laying Sod? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 07:28 PM   #1
Rewards Points: 422
Remove sand before seeding or laying sod?
We recently removed our pool, and there's about 3" of sand where the pool was. Do we need to remove the sand before we put down topsoil? I don't know yet if we are going to do sod or seed. Thanks.
Jim McC is offline   Reply With Quote
Old 09-22-2013, 07:12 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 596
Ayuh,.... Ya need to maintain whatever Grade ya got, whether with dirt or sand don't matter so much,....
Bondo is online now   Reply With Quote
Old 09-22-2013, 07:58 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
I would distribute the sand over the rest of the yard and till it all up and re grade. Then you have a uniform medium so that the new grass won't look different where the pool used to be.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-22-2013, 10:00 AM   #4
Rewards Points: 422
Thanks. I was told by someone that I need to remove the sand, because if I don't it will suck up all the moisture, and the grass will not grow properly. Make sense?
Old 09-22-2013, 10:15 AM   #5
PoleCat's Avatar
Some sand is a good thing, promotes aeration. Too much and you have a beach.
Old 09-22-2013, 10:44 AM   #6
DIY staff
Rewards Points: 7,174
Remove most of it---roto till what is left into the soil---add more soil to level the area.
Like Pole cat mentioned---the sand will cause the grass to brown out first ---not good.
Old 09-22-2013, 12:03 PM   #7
Rewards Points: 216
how big was the pool ?
Fix'n it is offline   Reply With Quote
Old 09-22-2013, 05:28 PM   #8
Rewards Points: 422
27' diameter. I'm trying to get rid of the sand via Craigslist, but no takers yet.
Old 09-22-2013, 05:52 PM   #9
Rewards Points: 91
I had a 25'x50' section that was all sand (about 6" deep) in my yard. I had 3 loads of topsoil brought in, roughly graded, then I tilled it in with all the sand, regraded, and planted seed. That was a few months ago, Bermuda is growing pretty strong (though, so are tons of weeds!). I'm going to reseed this week because there are several patches that the seed didn't last (wind, birds, etc).
I'd till it in, plant and go.
NegativeTen is offline   Reply With Quote
Old 09-22-2013, 08:00 PM   #10
Rewards Points: 684
With enough synthetic fertilizer and water you could have a putting green or remove it, stock-pile and broadcast it on the street this winter. I won't rust your car and the volume is only about 1.7 yards if my math is correct.
Old 09-23-2013, 09:05 PM   #11
Rewards Points: 422
Thanks guys. When is it too late to plant seed here in S/E Wisconsin? I'm about 25 miles west of Milwaukee. Thanks.
Old 09-24-2013, 07:58 AM   #12
PoleCat's Avatar
Fall is a great time to seed. Freeze thaw cycles work the seed into the soil and spring rains keep it wet when it sprouts.
The Following User Says Thank You to PoleCat For This Useful Post:
oh'mike (09-24-2013)
Old 09-24-2013, 11:56 AM   #13
Rewards Points: 422
So do I have until late October? Or will that be too cold?
Old 09-25-2013, 08:41 AM   #14
PoleCat's Avatar
There is no too cold. In fact I think I would wait until snow is coming then the seed will be covered and less available to birds.
Old 09-25-2013, 12:48 PM   #15
Rewards Points: 422
Really? And the seed will still germinate?
How to remove the Tub/Shower Faucet Lever Handle? compiler Plumbing 4 03-29-2013 08:04 PM
How to remove single 18" ceramic floor tile hkeiner Tiling, ceramics, marble 8 02-28-2013 10:56 AM
how to remove timer box for hallway lights at apartment building mikael6 Electrical 3 01-16-2013 09:31 AM
What is the best way to remove this tiling and how much to remove? wknddiy Tiling, ceramics, marble 6 12-03-2012 10:09 PM
Remove old hardwood glue b4 laying tile? MariJane03 Flooring 6 11-28-2012 11:52 PM
