Regrading A Yard - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 06:10 PM   #1
regrading a yard
can I regrade the part of a small side yard which gets standing water after every rainfall by adding top soil to that section?
francesbern is offline   Reply With Quote
Old 09-08-2011, 06:28 PM   #2
A Little Of Everything
Rewards Points: 1,356
You need to give us more information. That said, the general answer to your question is "yes." You do, however, need to make sure that your grading moves water AWAY from the house. You also need to control erosion, which is done with grass. If you can seed grass, water it daily, and get a good stand going quickly, then do that. If you're not sure you can do that, lay sod over the bare dirt, water it, and get it rooted in.
Good luck!
DrHicks is offline   Reply With Quote
Old 09-08-2011, 10:22 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
Ayuh,... Water flows Downhill....
It's comin' from uphill, 'n ya gotta find it somewhere, Downhill to run away...
Old 09-09-2011, 11:44 AM   #4
Do not understand the advice. This is a level piece of land. There is no uphill or downhill. The oddity is that one half of it does not absorb the water at the same rate as the other half. Hence, my question.
Old 09-09-2011, 07:25 PM   #5
Bondo's Avatar
Rewards Points: 338
Level land is rarely dead nuts Level...
if ya raise the wet spot an inch,...
It'll be an inch higher, 'n the water will flow elsewhere...
Old 09-09-2011, 10:20 PM   #6
Where are you located, and what kind of soil do you have in your yard?
Your yard is probably not as flat as you think it is, and is probably "pooling" in a low spot.
Other than that, I guess I'm unsure what you're saying and asking.
gas pressure line in middle of yard? BlueBSH Plumbing 2 08-01-2011 01:43 PM
How to Grade Forever-Flooded Yard? TheMedicsWife Landscaping & Lawn Care 1 04-12-2010 12:46 PM
Uphill neighbor says I'm flooding his yard.. EdwardC Landscaping & Lawn Care 10 04-11-2010 11:03 PM
Front yard decorating tips jay_chua Landscaping & Lawn Care 1 03-10-2010 08:00 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
